Sleeper_GT2
- Apr 24, 2022
Do they make high performance ignition coil for the 3.3 and if so would you change all of them at the same time
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Advertise with us!
Promo code: REDLINE
Where can I buy upgraded version?Kia already upgraded their plugs. If you have the one on the left you already have the upgraded version. If you already have new ones went bad, it’s JB4+stock ECU related. The fix you want should be a full tune or a back end flash, which adjusted the coil dwell.
I have to replace cyclinder5What's wrong with the original CoP?
Dealer. Make sure they look like the one on the left before paying for it.Where can I buy upgraded version?
They're very flexible (and multi-piece). You can just bend them around the stuff in the way, both during removal and reinstall.Oof, that one on the left is gonna be fun getting out of #4 cylinder.
Yes. There’s absolutely zero performance flaw for the newer version of our coil packs. If it still dies it’s simply just because the coil dwell of JB4+Stock ECU is off.So performance wise the stock/ OEM are the best? anybody with personal experience to share or recommend another brand
Really seems like same part# but different parts. That why I suggest ordering from dealer and confirming it before actually paying for it.Part numbers?
Were you throwing an error code specific to cylinder 5, and did you only swap the passenger rear coil to fix it? Because I've seen at least three separate cylinder numbering schemes, and this would confirm yours as correct.Hopefully this helps, it's correct.
Yes, error code: Cylinder 5 Misfire and yes I only swap that coil and that fixed itWere you throwing an error code specific to cylinder 5, and did you only swap the passenger rear coil to fix it? Because I've seen at least three separate cylinder numbering schemes, and this would confirm yours as correct.
