The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
If you're looking for even deeper bass (true sub frequencies) past the already respectable response with the factory subs, I don't think a slim or small tube sub will cut it. You're looking at a box in the trunk with a decent 10+" sub. Based on my testing, somewhere around 40hz the stock subs roll off pretty quick, so you need something that punches below 40hz which typically means 10" or larger.I would like a little more bass in my music when I want it. Not trying to rattle windows.
they drop off after 40hz because the oem amp has no power to push past that .If you're looking for even deeper bass (true sub frequencies) past the already respectable response with the factory subs, I don't think a slim or small tube sub will cut it. You're looking at a box in the trunk with a decent 10+" sub. Based on my testing, somewhere around 40hz the stock subs roll off pretty quick, so you need something that punches below 40hz which typically means 10" or larger.
If overall system volume isn't up to the task, you'll need to tap into the wiring harness and go with an aftermarket amp and upgraded door/tweeter speakers. In addition to any sub upgrade.
That's odd to hear since they're only 7". Did you doing any frequency sweeps/tone tests to verify? I was using a tone generator to come up with 40hz.they drop off after 40hz because the oem amp has no power to push past that .
hmm my 7 inch mid bass will play clean down to 34 hz if neededThat's odd to hear since they're only 7"
It's fairly easy for me to retest, I'll do that sometime soon to confirm. But it's feasible the amp is limiting the speaker's performance as you suggested, all things being equal. Stupid question, you say "mid bass", we are talking about the subs under the seat? Mid bass would be the door speakers in this config, right?hmm my 7 inch mid bass will play clean down to 34 hz if needed
yes i have a 7 mic summed freq rig that is very accurate for testing , bottom line they need more power to sound better , but you can replace those drivers with a better sub to gain even more output if needed . also they are running a true ib loading in the car using the frame rail for airspace that vents to the outside , lots of opportunity for better bass under the seats ,That's odd to hear since they're only 7". Did you doing any frequency sweeps/tone tests to verify? I was using a tone generator to come up with 40hz.
are the door speakers high-passed at all? would the front door outputs be a better input for the sub amp than the underseat sub outputs?Here's an input RTA of the subwoofer channel. They're low-passed around 50hz, anything above that is mostly coming from the doors (second pic).
i think the doors roll off naturally in the base system im not sure of the h/k set up has a band pass on it . if so then yes , if not then no ..are the door speakers high-passed at all? would the front door outputs be a better input for the sub amp than the underseat sub outputs?
Based on Aarvix's screenshot labelled FLL (front lower left?), it appears there's a steep drop after 50hz being sent to them so I'm assuming there's a high pass on the fronts as you suspect. It's really the only decent way to do this IMO, otherwise there could be phasing issues and definitely output level issues with two sets of speakers producing the same frequencies. Also a more efficient use of the amp's limited power output, you don't want to send frequencies you don't want/need to a speaker and waste those watts of energy.are the door speakers high-passed at all? would the front door outputs be a better input for the sub amp than the underseat sub outputs?
