I thought that is what was here. It's the only thing related to it I found.Do you have a wiring circuit diagram for the actual LCM? Similar to the schematic diagram for the IMS: http://www.kstinger.com/integrated_memory_seat_ims_unit-786.html
It is likely just a case of providing power and ground to the right pins for it as well.
Okay. Well, I've looked over and over again many times going back a long ways. If that diagram is available that you're looking for, which I don't know why it wouldn't be, I haven't been able to find it. I'm not sure if someone that has one or if I need to get some kind of a wiring diagram information for the entire car and then just locate that particular section, but as of now I don't have any more info on that.Thats a diagram of the connectors but does not give me any of the circuit logic, on its own that diagram gives me the IN and OUT but nothing in the middle, in a nutshell it tells me switch-wire-pins -> mystery stuff??? -> motor-wire-pins.
I need a diagram like this one of the IMS, thats what let me see how the switches/relays are wired together:
Looking more at the S14 connector, it mentions ICU which is the Integrated Body Control Module (which is in the car).
If it needs data input (not just power/ground) from that then using the LCM directly is likely out of the question. However, it may be possible to bypass it.
Here. The second picture has what is above everything in the other picture that you cannot see.Can you identify which connector # that is in the first picture you sent with the seat?
Again I'm going to warn you, DO NOT ATTEMPT TO DO ANYTHING WITHT HE WIRES WRAPPED IN YELLOW. Those are Airbags and they can and will pop if you put voltage on those wires.Couple of pictures here. The one with the white connector seems to have both a power and ground that comes from the main connector that I hadn't figured out what they were for. Same colors, but I'll need to verify those are those cables. Simply supplying power to them didn't make anything move. I undid a flap and was able to see these two gray connectors that plug together and the other picture that are just separated now. I was wondering as there seems to be a power and ground if the sleeve that goes the same direction as that white connector maybe leads to the lumbar control unit. If it does, maybe it's coming back down and going the way where the yellow sticker is and that leads to one of the motors. I may try supplying power there and see what happens.
oops I see that it wasn't the one wrapped in yellow but just had a yellow label, still tred carfullyAgain I'm going to warn you, DO NOT ATTEMPT TO DO ANYTHING WITHT HE WIRES WRAPPED IN YELLOW. Those are Airbags and they can and will pop if you put voltage on those wires.
Thanks. Yeah, I was wondering the same thing with the sticker being yellow. They don't go through the yellow tubing though, so at the very least it's not consistent and is dangerous as a result.Again I'm going to warn you, DO NOT ATTEMPT TO DO ANYTHING WITHT HE WIRES WRAPPED IN YELLOW. Those are Airbags and they can and will pop if you put voltage on those wires.
Without seeing a logical/circuit diagram of the LCM I really can not say what can and cannot be toggled through the LCM, I would just be "shooting blind"Looking at the S14 lumbar control unit, I can see all of those color coded wires plugging into the connector that connects back to bottom. One is called Power Ground, others are the direction to move, so 6 in total across the 3 motors. Would connecting ground to Power Ground and then positive to the direction I want a motor to move work? The gaps are super tight just to try it out with. I may have to try a very limited number of copper strands stuck into the connector hole.
GREATForget clarifying. It worked! Once I made those five required connections instead of just the two I had been trying which I was able to access once I traced the wires all in the main connector, I was able to adjust five of the eight motors, just like I already had been able to do, but this time all at the same time using the buttons on the seat! Thanks for your assistance with that, that makes those adjustments much more helpful.
Now being that I figured out by now that the other adjustments weren't part of the memory unit, I'm not surprised to find out they still don't work. There must be some other connectors in the main connector that lead to that lumbar control unit, so just need to figure out what connections to make there and now I have hope that those can be made to work.
Also, when I first hooked up the power this way, the seat slid backwards quite a bit and then stopped. I've since removed power and put it back and it did not do it again, so I'm not sure if that was the memory of something it had, but as long as it doesn't do that every time I powered up, it would be a big deal. Although if it dispenses money every time it does that, I would be fine with it, because when I first powered it up a dime fell out.![]()
Thanks. Do you think it's worth it and safe trying to hook it up the way I describe to see if it would work?Ok looking at the connector diagrams of S14, pin 12 is a fused input, but pin 11 comes from power switch relays built into the ICU (the "fuse box" in drivers kick panel). These switches are something that the car uses instead of relays
Thus without the ICU, it looks like you wont be able to use the Lumbar Motor to control it.
You can however build your own controller using a 4 channel 12v relay board.
I made a diagram if you wanted to go this route:
