Holy F yes. That is significant tire damage and the tire needs to be replaced. It may not come apart on you driving to the tire shop a few miles away at street-speeds, but something like that is just going to tear open more and more at faster speeds.
No other evidence of why this is here, it may have happened a long while ago. I don't inspect the tires that often. I wouldn't have even noticed if I didn't randomly pick this tire to get sizing/directional data from it.That's ugly. Any wheel rash? Maybe a jagged pothole did that.
Agree, I moved the car a few inches to get better access to the gash and it's very superficial, so I think I'm fine. I pulled the tiny flap of rubber off to verify the crack only runs across the surface, not into the tire. There is also not anything punctured/stuck.Can't tell the depth from the picture, but sidewall damage would have me concerned
I think it was a very pointed object that traveled at an angle upward and through the side, or a rock that didn't move and scraped upward. I did park this car in a fairly rough parking area outside of town 5 or 6 weeks ago.Not a chance that is minor. The rip goes all the way into the edge of the tread. My guess is that the belts are stressing apart already and the rubber is flexing, thus the rip. If this is just a surface blem, why is the vertical line background to "Michelin" distorted?
That’s what drifting does to tires. They just basically drift race till they shred.That's ugly. Any wheel rash? Maybe a jagged pothole did that.
You would be very much fitting of your username if you don't have that changed. Please get it swapped as soon as you can.I think it was a very pointed object that traveled at an angle upward and through the side, or a rock that didn't move and scraped upward. I did park this car in a fairly rough parking area outside of town 5 or 6 weeks ago.
I have lots of pictures now, and will check on it in a few days, and a few weeks, to see if the crack expands. If it doesn't, it's likely just ugly.
Also noted that the side of the removed flap area that has been exposed has a layer of grime on it, matching that of the rest of the tire's surface. I think this happened a while ago. The crack doesn't expand into the tire, there's no 'depth' to it.
Was worth being concerned about when I found it just now but the panic light has been turned off.
Appreciate everyone's concerned responses and feedback. Good to know you don't want me dead.![]()
