[VENDOR][FS]: Kia Stinger 3.3T - Wagner Tuning Competition Intercooler - K8 Stinger Store
Daniel @ K8 Stinger Store
Authorized Vendor
Is excited to present to the Stinger forums:
(BUY NOW)
Description:
Kia Stinger Competition Intercooler upgrade
This high-performance intercooler has a new competition core
The aluminum cast end tanks was optimized in CAD simulations
The newly developed high-performance intercooler core is very lightweight
This core offers a 175% larger frontal surface area & 183% more core volume
An incorporated air baffle inside the inlet ensures uniform filling of the intercooler.
As a result of this technology, it provides excellent cooling properties with minimal back pressure
This provides the adjoining components enough air flow by using a specially prepared air baffle to assist with cooling
The installation is done by replacing the original intercooler with this upgraded intercooler and is a direct 1:1 replacement
Now available with optional charge pipe upgrade or optional carbon fiber air ducts
Specifications:
(1) Competition Wagner Intercooler
(2) Specially prepared Air Baffles
(2) Silicone Hoses (Black)
(1) Installation Booklet
(1) Mounting Bracket
Weight: 32.90 lbs
Inlet diameter: Ø76 mm/3"
Outlet diameter Ø76 mm/3"
Installation instructions: (FOUND HERE)
Vehicle Applications:
2018-2023 Kia Stinger (3.3T Models Only)
THANK YOU FOR LOOKING!
Will this fit with the trans cooler or the BMS trans cooler?
I couldn't tell you on that one, as we don't do installs here, and I am not sure where that part gets mounted.
However, as long as it doesn't interfere with the mounting of the original intercooler, I don't think it would be an issue as the Wagner is a little larger.
Do you notice your 3.3T engine is running too high of a temperature?
If so, you need to check out the Wagner Tuning Competition Intercooler.
This competition-style intercooler comes equipped with a 175% larger frontal surface.
Wagner's Competition Intercooler is lightweight and is a direct 1-1 fitment to your stock intercooler.
(CLICK THE IMAGE BELOW TO MAKE A PURCHASE OR FIND OUT MORE INFORMATION)
