Oil catch can leak????
SneakerB
I noticed a hissing sound coming from the engine bay popped the hood and realized it was coming from the end of the hose going into the engine, it was still on an connected but somehow the hose clamp was loose and it was sucking air in, how screwed am i? I feel like that was pretty horrible on the engine!
not screwed at all. Nothing to worry about. Just tighten it up and you’re good to go
Worst case it might have leaned out the mixture slightly, but less likely to do so under moderate or higher throttle as there is little vacuum in those cases. If no CEL was thrown, then no problem.
