davebo
Hah, I forgot what thread I was in, you're right!That’s discriminatory.
First of all, it is a problem only if you have the limiter and it annoys you. An ECU tune is the only solution. GT 2 AWD NOT REALLY A STINGER!?!? Apparently if you lobotomize the actual speed limiter (from factory) you void your drivetrain warranty: I've heard nothing different since this thread.What is the solution for this awd speed limiter problem?
Dedicated ECU tuneWhat is the solution for this awd speed limiter problem?
And? How fast?I found out a few days ago when I tested it in my local "Mexico"
I'm going to pretend I'm psychic and say 167And? How fast?
Hit 146 before I entered my braking zone, But the car def wanted to keep going. I am also on my Opposite of mexico weather tires so I really didn't want to push it any higher than that.^^That will take some long straights and no interference. Hah.
Yeah, I've had the Nitto Motivo A/S UHP up to over 130. But it was the (still pretty new) PS4 that took me up to 155; and I was still pulling c. 1 MPH per second when I called it good.Hit 146 before I entered my braking zone, But the car def wanted to keep going. I am also on my Opposite of mexico weather tires so I really didn't want to push it any higher than that.
Its not really a suggestion, its pretty much the only way to do it. Apparently the Lap3 Pro Tuner can do it as well but Idk much about that specific device to verify it or not. What I can tell you is that, my 18GT2 had a 130mph Limiter on it (Kia changed it from 140 to 130 at some point) with its stock ECU, and Now that I have a Lozic ECU, the 130mph limiter is def no longer there. I found out a few days ago when I tested it in my local "Mexico"
That is certainly one way of doing it, but their wont be many left.Speed limiter delete I purchased from terry. Have yet to install but wanted just in case I wanted to remove the governor. Only $100 if you PayPal terry. My car came with the 18inch all season tires and I tapped out at 130mph pushing it.Stinger/G70 Speed Limiter Delete - JB4tech.com - International Turbo Tuning Discussion
Stinger/G70 Speed Limiter Delete Kia & Hyundai Turbowww.n54tech.com
no, they dont1. Because a lot of people take their cars to the track or places where they can legally open it up.
I mean, enough people do to warrant BMS to make an override, and ALL the ECU tunes raise the limiters, so the reasoning is clearly there. saying they don't (especially to a 4 year old comment) is pretty ignorant.no, they dont
Yes, a very small %. And around a track, you need straights/acceleration rates that will get you to those speeds, so even though the car may go 140mph in a straight line with a straight road, getting to 140mph on a track with curves and straights is another thing...I mean, enough people do to warrant BMS to make an override, and ALL the ECU tunes raise the limiters, so the reasoning is clearly there. saying they don't (especially to a 4 year old comment) is pretty ignorant.
I mean from a dead stop, sure, it might be difficult, but considering a good portion of straights have a nice sweeping curve off them beforehand, you can sometimes be doing above 100 by the time you get out of a turn. Its not that difficult to reach 140-150 if your corner exit speeds are already decent. It might be difficult in your GT line specifically, but not so much in the 3.3TT.Yes, a very small %. And around a track, you need straights/acceleration rates that will get you to those speeds, so even though the car may go 140mph in a straight line with a straight road, getting to 140mph on a track with curves and straights is another thing...
Honestly, I'd expect a GT1 or 2 to be flying over the fence if they were trying to get the exit speeds to exceed 140mph in the straights. Unless we are talking some absolutely GIANT straights...but back to my point...it's just a very small % of stinger owners that would be actually doing this.I mean from a dead stop, sure, it might be difficult, but considering a good portion of straights have a nice sweeping curve off them beforehand, you can sometimes be doing above 100 by the time you get out of a turn. Its not that difficult to reach 140-150 if your corner exit speeds are already decent. It might be difficult in your GT line specifically, but not so much in the 3.3TT.
I would expect you to know that though if you have tracked your Camaro before.
