So I just got some lowering springs/brake lines and I want to install them. Fine. So this is the first time I have removed my TSW Sprints (19s) and I don't know the exact socket to use. I have deep sockets, shallow, impact, normal, metric, and imperial. I find a socket that seems to 1) fit inside the lug nut cavity and 2) fit the nut. Its a 21mm deep impact socket. Fine, well and good.
I use a 6" extension and a breaker bar, and I turn it to the left. Per usual, there is quite a big of resistance, which is to be expected. The socket moves, but I don't feel the nut moving. Did I just round a nut? Anyway, I am freaking out, and I turn the socket both left and right, trying to remove it.
It's stuck.
1) How do I remove a stuck socket?
2) If 21mm is not the correct socket, then what is?
Help me obi-wan kenobi, you are my only hope.
It's stuck.
