18" Wheels that fit Brembos, Stinger GT
PAdutch
I would like to create a list of 18" wheels that fit over the brembos on Stinger GTs. I recently bought a set that the inside diameter would not fit.
If you would like to contribute please post (include pics if possible) in the following format and I will update the list here:
Make and style #:
Width/Offset:
Interference Issue:
Wheels that do fit:
Fast FC04
18x8 +30 front/back
RWC MHK80
Size: 18x8.0 ET 33
Center Bore: CB67.10
Wheels that do not fit:
JNC 026
18 x 8 et 35
Valve Stem bump hits outside of caliper
I recently bought a Stinger GTS which came with Pilot 4s summer tires. Not a big deal as I usually by a set of winter rims anyway. These wheels did not fit.
JNC 026
18 x 8 et 35
These wheels do fit:
Fast FC04
18x8
+30 front/back
Does anyone know if these wheels will fit on a 2019 Kia Stinger GT2/Limited?
(Can’t post links)
Euro Design Tech Matte Gun Metal
18x8/5x114.3
Center Bore: 72.6
Offset: 35
Would I need to do anything else like any sort of adaptor in order to install these wheels+tires onto the Kia?
(Can’t post links)
18x8/5x114.3
Center Bore: 72.6
Offset: 35
I appears that you would not have the problem I did as the valve stem is located in the typical spot. I think the only question then is do the spokes of the wheel clear the outward face of the caliper. Have you asked the supplier?
These are my winter wheels. Fit great with Brembos.
RWC MHK80
Bolt Pattern: 5x114.3
Offset: ET33
Fast FC04 18x9 +40 fits the rear
Confirmed to fit:
18x8/5x114.3
Center Bore: 72.6
Offset: 35
I can no longer edit the first post. Im guessing there is a time limit. Anyone know if editing old post is able to be changed.
Make and style #:
Width/Offset:
Interference Issue:
Wheels that do fit:
Fast FC04
18x8 +30 front/back
RWC MHK80
Size: 18x8.0 ET 33
18x8/5x114.3
Center Bore: 72.6
Offset: 35
JNC 026
18 x 8 et 35
Added here so there is at least a list.
Our center bore is 67.1, right? So those 72.6 bore wheels would need a hub-centric ring? I'm assuming most manufacturers / installers have those on hand, and it's only a problem if the bore is SMALLER than ours (i.e. would have to remove material)?
Correct, larger than 67.1 should get a hubcentric ring. Smaller will not work.
As they say... bigger is better
Do wheel manufacturers generally include rings? Or are they easily found at most wheel places?
I would imagine most wheel places have them. They are also easily and cheaply available online.
