The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Advertise with us!
Timing is everything
Get the best deals on wheels!
Vehicle Specific Solutions
Brands you can trust
Promo code: REDLINE
Kia Hyundai Auto Racing
Authentic Tuning
Advertise with us!
Promo code: REDLINE
Authentic Tuning
I don’t think so. I could just cry. My husband recently past away and I know nothing about cars. The tow truck came and couldn’t tow it because it won’t go out of park. It’s like it’s immobilized somehow.Is your battery dead?
A flat-bed should be able to take it no matter what. May have to sign something that releases the driver of any damage if the car won't drop out of park.The tow truck came and couldn’t tow it because it won’t go out of park. It’s like it’s immobilized somehow.
Oh my gosh guys thanks so much for the feed back. Finally a tow guy came this morning with a jump box and it crank right up. I let it run for about 20 minutes snd took it around the block. Hopefully it will crank when I go back out. Do you think I should still take it to the Kia place snd have them check it??I just bought a 2020 Kia stinger drove it around 2pm got back in and it won’t start. Matter of fact it does absolutely nothing. The doors won’t locked nothing. Can somebody please help me?
Yes, for sure. A 2020 Stinger resold has sat for a while if you're experiencing this. These are really robust batteries, as long as they are not damaged from being completely drained. When you experience needing a jump again, you'll have the confirmation that the battery does not hold a charge. My battery is over three years old; the car has never sat for more than a day or two, and it still kicks over like it did on the dealership lot when I drove away. Be ready: this is an expensive battery, several hundred dollars, so, get over the shock now.Do you think I should still take it to the Kia place snd have them check it??
Happy to hear it's just the battery - As said take it to the dealer and have them swap the battery, at the very least it will start the documentation process if it happens again.Oh my gosh guys thanks so much for the feed back. Finally a tow guy came this morning with a jump box and it crank right up. I let it run for about 20 minutes snd took it around the block. Hopefully it will crank when I go back out. Do you think I should still take it to the Kia place snd have them check it??
What goes into that? Is the coding esoteric stuff that only the dealer can do?Does our battery need to be coded? I know Audi and BMW need to be coded when you replace the battery.
"Fail", how, exactly? How does a battery that his hooked up to a car fail "prematurely" because it wasn't coded? This sounds like conspiracy territory to me.Yes unless you buy their programming tool.
Not properly registering the new battery will cause it to fail prematurely.
