JB4 causing all dash lights and warnings
Some Dood
I installed the JB for a few days ago with a USB cord. Working fine.
I got my Bluetooth adapter today so I put that on. The app was working fine but didn’t show me any gauges.
I found out is because I didn’t have the OBD sensor hooked up. So I just plugged in the OBD plug and connected it to the JB4. When I started the car my gauges were working but all the dash lights came on for tire pressure, collision, etc. No codes Are coming up on the app. I installed V12 firmware again but the lights are still on.
Not sure if it's related but most initial install problems sort themselves after a day or two.
I’m going to let it sit for the night and then I’ll check it in the morning. Maybe disconnect the battery and see if that helps. Everything was working before I did the OBD sensor.
