Thrashmetl
- Feb 26, 2018
I have a Stinger GT2 I plan to lower on either ARK or Eibach springs in a few months. I’m a bit confused on the alignment necessary after the fact and, to be honest, I know absolutely nothing about alignments. Should any alignment shop be able to do this, or should I take it somewhere that has experience with aligning dropped cars? Do they just return it to factory specs, or do they need to take something else into consideration since it’s dropped so the tires don’t wear unevenly?
Also, I know the headlights will need to be readjusted if I go with the Eibach’s and I essentially know how to make the adjustments, but what is unclear is where they should be aimed? Do you have to shoot them up against a wall before the drop and mark the wall, then aim them based on that after the drop? Or is there a better way?
Related question. Since the ARK springs are an even .75” drop front and back do the headlights still need to be adjusted?
