Tonkabob
2500 Posts Club!
I'm trying your settings. Called it Wayne.I have a 2019 GT2 with AWD.
More comfortable ride for the commute but without the floaty feel, I think it is probably close or similar to the built in Comfort setting but might be slightly firmer.
I shall test this at lunch! I might try a tad bit firmer to see how close I can get to the sport and then a bit more.
Would you guys rate this as a significant improvment (like sway bars) or more subtle?
I have Eibach sways and now the Mando. I can say for me the sways made a great improvement. Now, with the sways and the Mando... it's that much better. Hard to say which one is the better bang for the buck as I have only had the sways without the Mando and not the other way around. I do feel though, that the Mando is a great compliment as it gives those minor tweaks that I certainly notice. Sooo... that's my answer and I'm sticking to it.![]()
I just came back from my test of the Wayne settings. Still seems bouncy, but much better than the original Wayne settings. It seems @Waynerm002 is right with his new settings being possibly between or a little closer to the comfort settings on the app. We're getting there...Well, Wayne is getting there, I'm just copying him and giving my two cents.![]()
You can firm up the ride a bit by going to 30/40 and bump the handling to 35/45. I still want to maintain some ride comfort while keeping the handling balanced for a Sport setting but I think with the Michelins, it might be better to stay a bit softer. I'm working on the 1% changes now to see how it feels. I think I will set the Handling to 30 to just work on tuning the Ride then focus on the Handling later.
Thanks, I guess I will order and join this experiment.
This morning I went over into the Advanced section, it's normal setting is 40/60 for both Ride and Handling. The car is certainly tighter overall and on smooth roads, it feels good but a tad on the firm side. On bad roads, it rattles the car a bit and you feel the hits from the bumps and ruts but it isn't too bad for a sporty feel, I'll just have to tune it to be a bit softer. I didn't do any adjustments for speed, so it was like on the Basic section, 40/60 at all speeds. I'll play with it to ramp up to 60% at 70 and drive it around this weekend to see how it does.
Don't you have some contact / relationship with the guys? They need to add an export/import function so we can share files..
