Many thanks to all that replied. Combined everyone's suggestions and got it done this evening. While the front rotors practically fall off, the rears take a bit more finesse. To anyone struggling, here's some notes and what I ended up doing:
- Researched ebrake functionality, and confirmed the ebrake is indeed off if there is no indicator in the dash. Caution, sometimes it auto engages when in park, so double check no indicator light when in park.
- The ebrake shoes rest very close inside the hat, so close there is absolutely no play, at least in my case. Hitting the rotor does absolutely nothing except potential damage. Yanking, pulling, prying may not work at all.
- To compound the problem, the back side of the rotor is blocked by the heat shield except where the caliper lives, so you can only tap it with a mallet in the opening. And since there's no play in the rotor, hitting one end of the rotor just causes it to bit down more on the other end. And since rotor doesn't spin, so you're stuck hitting it in just one area. This method is futile.
- To nudge it out, I had to tap it loose by hitting opposite ends of the rotor back and forth repeatedly. Since rotor is blocked by the heat shield I stuck screw drivers into the center of the rotor, at 10 and 2 position, and hit them right above the rotor from the inside wheel well out. It's close quarters so take the time to be careful and not hit anything other than the screw drivers. I went back and forth, hitting each a couple times before moving to the other. You can check if there's movement by looking in the two little screw holes. If you see the gap widening you know you're doing it right.
After maybe 2-3 minutes the darn thing slipped off.
Here's what the setup looked like:
Appreciate all the input and knowledge sharing. Good luck to those attempting rears hopefully your situation is a lot less hassle.
