[VENDOR][FS]: Kia Stinger - ARK Performance GT-F Lowering Springs - K8 Stinger Store
Daniel @ K8 Stinger Store
Authorized Vendor
Is proud to present to the Stinger community:
(BUY NOW)
Description:
ARK Performance offers high quality lowering spring kits that provide a clean drop, comfortable ride, and greater performance. ARK GT-F Lowering Springs are designed to provide drivers with a dramatic improvement in handling characteristics and cornering. Drivers will feel a significant increase in steering response, better cornering grip entering and exiting out of turns with reduced body roll, and a lowered center of gravity while maintaining smooth and comfortable ride quality for daily driving.
ARK Performance GT-F Lowering Springs are designed by their suspension engineers and tested by professional drivers to find the perfect ride height and spring rate to deliver the best ride quality and performance without neglecting the driver's safety on and off the track. Their springs are the perfect combination with your OEM shock absorbers. They provide an excellent stance with your stock or aftermarket wheels while keeping your tires on the road for maximum grip.
Each spring is made from the highest quality materials, with the leading coiling technology, and is powder coated to prevent corrosion. ARK GT-F Lowering Springs for your Stinger provide the ultimate suspension balance to give you confidence on any road or course.
Features and Specifications:
Includes (1) set of 4 lowering springs
Spring Rates: 3.2 kg/mm Front/4.9-5.8 kg/mm Rear
Drop Height: 0.75” Front/0.75” Rear (RWD)
Drop Height: 1.15” Front/1.0” Rear (AWD)
Improves Handling and Cornering
Works With OEM Shock Travel
Comfortable Ride Quality
Reduces Body Roll
Vehicle Application:
Stinger_Ark_Lowering_springs_2_1024x1024.jpgStinger_Ark_Lowering_springs_1024x1024.jpg
124ecf58-e2d3-4642-a2d9-998bc1c3735c copy.pngImage 8 copy.pngImage 6 copy.png
THANK YOU FOR LOOKING!
The Kia Stinger ARK Performance GT-F Lowering Springs
(BUY NOW)
Description:
Reduces Body Roll
I’ve never seen this type of measurement for spring rates but I am no expert. How does this compare to the spring rates of Eibach?
That's a great question, I'll have to check with Eibach since I dont think they openly advertise the spring rates
As for the measurement, you can convert it. Spring rates can be measured in a variety of different ways
Due to the specs on the rear spring rates, are they a progressive spring vs a linear spring?
Also, I’m wondering how these work on the ‘22 2.5T as there isn’t as much weight over the front end compared to the 3.3. I would think the springs should be specific for each engine with different spring rates due to different weights. I would think the front would sit a tick lower on a 3.3 vs a 2.5/2.0 due to engine weight.
The Ark springs will fit all models, trims, and engine sizes of the Kia Stinger. Currently, there are no specific 2.5T springs that I know of. I will reach out to Ark to find out whether or not the springs are progressive or linear.
Ready to lower your Stinger but looking for the best fitment?
Gain better performance, handling, and looks with the Ark GT-F Lowering Springs.
Ark GT-F Springs are made from industry-leading coil technology and a corrosion-resistant coating.
These springs help lower your center of gravity and add a more dynamic steering wheel feel on the road and on the track
(CLICK THE IMAGE BELOW TO MAKE A PURCHASE OR TO FIND MORE INFORMATION)
