Will these wheels work?
19ceramicgt1
Looking at getting a new wheel setup for my 2019 gt1 rwd stinger and am seeking assistance on whether or not this setup will fit without spacers and having clearance to prevent any rubbing on suspension components or brakes.
Front:
19x9 45mm offset with a 245-35-19
Rear:
19x9.5 52.5mm offset with a 285-30-19
I appreciate any assistance that can be offered.
Front:
Rear:
I'd say looking at those figures your wheels are gunna stick out a fair bit could even go past body panels...also your front geometry will change ie neg-pos camber...i suggest going to this site and comparing your sizing as this will tell you everything you need to know
Kia Stinger 2018 - Wheel & Tire Sizes, PCD, Offset and Rims specs
On the contrary, those wheels will be sunken in too much.
The front offset is too high and it will hit the caliper
The rears will work, however I think you may hit the rear strut/shock as the 9.5 is wider than stock.
You will certainly need spacers in order to make those work on the Stinger.
