Will these wheels fit?
anvasquez15
Considering buying these after market wheels. Just wanted to make sure they fit. Lug pattern and dimensions work but the hub bore and offset I’m unsure.
Offset will be fine and that hub bore is pretty standard, you can just get some hub centric rings to reduce the bores to 67.1 and all should be good. What size tires are you planning to run on them?
Just some 225/45/18s
You will still sit a good amount inside the wheel well with that setup but everything should clear just fine
