Will These Rims Fit?
KYStinger09
So I was looking on Facebook marketplace the other day and saw a set of TSW Sebring rims and tires for sale, only problem is that the rims have a width of 10 inches on a squared setup, with an offset of +30 all around, will these fit on a stinger? if it helps the wheels are coming off of a newer genesis G70
I haven't seen anyone fit a 10" wide wheel in the front of a Stinger yet so I find that doubtful.
Maybe they are coming off a G70 for a reason? Likewise, I haven't read of anyone with 10" wheels in front. I'm guessing that to clear the suspension you'd need somewhere in a 20 offset, and then you'd be into the fender/wheel well. I go with the wheel pros rather than try and figure this stuff on my own. The Net is not a reliable source for information either. Hah.
In order to fit 10” in the front, you would need <20 offset min to clear the front struts, and there would be ALOT of poke. Most aggressive fitment I’ve seen in person for fronts is 19x9.5 + 25 and it pokes over 1/2”.
