Wheels/Tires
btsking
Since I need to get new tires, I'm also looking to get new wheels. My car is stock with OEM 18s on them. I have a couple of questions.
  • If I wanted to move to squared 18x8.5, what would the offset need to be to keep it similar to the 18x85 +34? I'm assuming the width of the wheel affects the offset but not for sure.
  • Could I go 255/(35 or 40) for the tires?
Thanks!
In terms of handling, all the important parameters like roll center, scrub radius, etc. are all referenced to the centerline of the wheel/tire, so offset is not affected by wheel width. That said, if you want wheels wider than 8.5, ET34 most likely will have trouble clearing the struts. Some folks are willing to go with less offset, in order to mount 9" or even wider wheels, and just live with the consequences. IMO, not ideal from a suspension geometry POV, but different folks have different priorities.
To me, wider than 8.5 up front is rather pointless. For a square setup, 8.5 will easily accommodate 255, so rear wheel power handling is plenty for 3.3T stock HP/TQ or even a bit over. If you've modded up your engine output quite a bit more, then you might need wider tires out back to handle the added torque. For 2.5T and 2.0T, wider than 255 isn't necessary.
For street, our G70 6MT run 255/40R18 square on 18x8.5. I prefer offset around 38-40mm, which are perfect for the rear axle, and just run 3mm or 5mm hubcentric spacers up front to correct offset to within 1mm of stock 34mm. You could also just get ET35 all around; that'll work just fine.
I appreciate the reply. I am 3.3T AWD but yeah that’s what I was thinking - 18x8.5 +35 all around with 255s. Is the 35 vs 40 just a look thing or is there a performance aspect to it?
Wheel offset determines the scrub radius of your suspension geometry. Most RWD cars these days are designed with scrub radius very near zero or a bit on the negative side, especially for the front wheels. This improves braking stability and minimizes bump steer mid turn. It's okay to vary a few mm's on side or the other, but it's best not to veer too far.
Rear wheels aren't as critical, which is why OEM offset range from 34mm or 46.5mm. Stay in that range and you're okay.
For many drivers, though, none of these things matter and it's all about looks and the "stance". Everyone's entitled to their priorities. It's your car and your disposable income. Do what makes you happy.
