Wheel/Tire Question
Theil24
Hi,
I'm currently running aftermarket wheels. My setup is:
Front: 20x9 +35 245/35/20
Rear: 20x10.5 +42 285/30/20
My PS4S's will need to be replaced soon. Was looking to get the Continental DWS06 Plus as I've read great things about them.
My question is would I be able to run 255/35/20 in front and 295/30/20 in the rear? The tire/wheel calculators I've checked show the tire would be 5mm closer to suspension and stick out 5mm, and the sidewall height would be about 3mm taller. Rather small changes with a bit more contact patch. I'm going for less of a stretched sidewall look.
Any issues with a slightly wider tire? Am I missing anything?
I'm lowered a 295 would fit mine but would rub on the fender lip, your asking to push to the extreme a bit much
