Water spots on trim
mattbrac3
San Diego, CA
I haven’t seen anyone post about this is there a way to get these water spots off does anyone have any tips or tricks.
Following.
I know these are removable but I keep forgetting what the different polishing liquids are called
Lots of info here: Trim looks like crap
Consensus is that the trim is actually stainless steel, and the discoloration is oxidation. It seems like Meguier's Ultimate Compound is a good cleaner for the piece, but it should polish out.
Meg's cleaner wax is also recommended. You may have to rub vigorously. Failing that, many have been replaced under warranty. This is not simply a single discoloration cause; because some pieces won't clean up, and others clean easily with no effect to the finish.
