Water in E30 mix?
Wafernut
My stinger was in the shop for 3 weeks after getting ran off the road. I have an e30 mixture with 93. The exhaust didn't sound normal. MBRP catback. No stutterings yet. Do any of you guys/gals now what to do if you suspect water in your gas tank? Thx
Maybe put more regular gas in it and then drive slowly and brake often to mix it up? Is 3 weeks enough time for the ethanol to go bad?
2 months E30% mix on mine and fired right up. I store mine full tank and with stabil.
I think it's more of an old ethanol in the gas tank. I also had an E30 mix with a little of a gallon. Sat for 3 weeks and ran fine. I haven't had a problem after more than a yr. It ran fine... I wouldn't worry about myself. Hope this helps.
