3.3TT Video of cat delete downpipes and stock mufflers?
Discussion in 'Engine, Drivetrain, and Exhaust Discussion' started by Jonathan Lasich, May 23, 2018.
  1. Jonathan Lasich
    Jonathan Lasich Canada Active Member
    257
    87
    Anyone heard a video of what the car would sound like with just the cat delete downpipes installed and the rest of the exhaust OEM?
  2. StungBlueGT2
    StungBlueGT2 United States Stinger Enthusiast Sustaining Member
    877
    542
    98
    Florida, U.S.A.
    I doubt you will find anything as I dont think anyone would do this.
    The main reason to delete cats & add downpipes would be to increase flow and HP, but think the restrictive OEM exhaust & mufflers would defeat that purpose. If you’re going for more performance then curious why only do half the upgrade?
  3. Jays_stinger
    Jays_stinger United States Member
    75
    50
    Anaheim, CA
    Possibly going for a better sound but not to obnoxious is why keeping the OEM mufflers is a thought?
    I have muffler delete plan on upgrading the exhaust more (not with bolt on exhausts) but in all due time since it sounds great with the muffler delete.
    I have a video on my youtube channel.
  4. Jonathan Lasich
    257
    87
    I am looking at an eventual ECU tune on the car and have been told that the secondary cats are a point of restriction and a point of heat build up under the car. I was also looking at eventually doing the Kia bi-modal exhaust for a little more throaty sound outside the car, but minimal in-cabin increase in noise. My worry is: both done at the same time might result in too great an increase in the in-cabin noise, in which case you'll be reading my obituary when my wife gets done with me. So, if the downpipe and cat delete alone will increase exhaust noise on it's own, then I would stop there and leave the OEM mufflers in place. If no significant change in sound with the downpipes, then I can pursue the bi-modal exhaust when funds are available.
    The ECU tune and cat delete will add more than enough oomph to the car. Changing rear mufflers would make an imperceptible difference in power at that point.
  5. Kamauxx
    3,792
    1,463
    Are you asking about installing a new, catless downpipe or just deleting the cats on the OE downpipe?
    Before buying a catback I did consider deleting the cats for a bit of extra sound and better flow. The factory downpipes aren't very restrictive once the cats are gone so I wouldn't bother swapping them out. The reason I didn't do it is because Tork MS said they had issues with the car throwing codes after removing the cats, even though the cats themselves have no O2 sensors. (look through their youtube videos for more information)
    I think a better option for someone who doesn't want to spend a bunch of money, wants to increase the exhaust's flow, and wants more sound would be to swap out the stock resonators for aftermarket, high flow resonators.
    • Agree Agree x 1
  6. KLR STINGER
    KLR STINGER Canada Active Member
    432
    309
    68
    I have downpipes and magnaflow catback coming. I suppose I could do just downpipes first to get a video of those alone first. it'll be a couple of weeks though as neither has shipped yet.
    • Useful Useful x 1
  7. eflyguy
    eflyguy United States 1000 Posts Club! Staff Member Moderator
    2,335
    812
    Georgia, USA
    I think you're missing the point.
    Cat delete won't do anything if you keep the stock mufflers. It needs to have better flow all the way thru, not just at one point.
    • Agree Agree x 1
  8. Jonathan Lasich
    257
    87
    KLR STINGER,
    If would be wonderful if you could do that, and would be VERY MUCH appreciated!! Thanks!!
    I'm not in a rush. I'm about 2 months away from completing the 1000 km break-in.
  9. Jonathan Lasich
    257
    87
    OK, so now I'm confused!
    I was under the impression that the Stinger had a 2 stage downpipe: short primary downpipe right after the turbos that have the primary cats with sensors that control emissions; and secondary longer downpipes that have the secondary cats with no sensors and no effect on emissions control (these are the ones that Jun BL sell without the cats). Tork MS suggested that I delete the secondary cats as they found a restriction and heat build-up related to the secondary cats. If I'm wrong, please feel free to correct me.
    • Agree Agree x 1
  10. Kamauxx
    3,792
    1,463
    Here's Tork's video with deleted cats. It created over boost and put the car in limp mode. He put the cats back on and the problem was corrected.
    • Informative Informative x 1
  11. Jonathan Lasich
    257
    87
    Yeah, but that was with the piggyback tuning unit. I don't believe that is anymore a problem now that he's got the car ECU tuned.
  12. KLR STINGER
    432
    309
    68
    I get mine tmorrow, should
    Jesus man..drive that thing. I get mine tomorrow and should be past the 1000km by Sunday! No idea when I am gettign the downpipes or magnaflow yet, so when I get it'll stage in in that order.
  13. StungBlueGT2
    877
    542
    98
    Florida, U.S.A.
    My understanding is that the cats cause the most restriction, but the OEM mufflers and exhaust are very restrictive too and will cause back pressure. We're just stating that unless you "unclog" the muffler restriction too you wont see the gains your hoping for when deleting the cats & adding a downpipe.
    I'm unsure about the 2 stage downpipes so ill let someone else chime in on those questions.
  14. Jonathan Lasich
    257
    87
    Ha!! Funny!! 4.1 km to work from home. Only so many times I can do the main street Brockville on the way home!! Also leaving for a 2 week vacation in Greece in three weeks, so the Stinger will be parked in the garage for 2 weeks.
  15. Jonathan Lasich
    257
    87
    I understand what you're saying and that's why I'm looking at the bi-modal exhaust, but death by slow torture ("You ruined the car!!") is much worse than a few lost horsepower!!
    What's also interesting is there was a thread on the forum of someone's build. He had the Jun EVC exhaust, with a JB4 piggyback tune, and he dyno'd the car at various stages. If memory serves me correctly, stock tuning---closed to open valves=+10 HP. Tuned--closed to open valves=same HP--no difference. OEM mufflers maybe less of an issue with the increased boost?
  16. Mr GT-2
    Mr GT-2 United States Active Member
    115
    47
    Pa
    Well I know magnaflow and borla has cat back kits for around 1200 so I'm leaning towards borla but will see and as for intake I'll probably do the k&n kit last as the cold air intake does very little for performance but more so for sound.
  17. Bear
    Bear United States Active Member
    277
    133
    Northern Virginia
    There are primary cats and secondary cats, both are on different sections of pipes. The downpipes have the secondary cats, and there are no O2 sensors. You won’t have CEL issues by slapping some downpipes on.
    Tork was was running primary and secondary cat deletes. They had overboost issues with both primary AND secondary cats deleted.
    Cats (non hi-flo) on any car are very restrictive. The primary cats on the Stinger are by far more restrictive mainly because the exhaust coming immediately off the turbos are about an inch in diameter and not true 2 1/4”.
    Best way I could explain the exhaust sections is:
    Turbo -> Test pipe (primary cats and contains 02 sensors) -> Downpipe (secondary cats) -> Cat-back
    • Informative Informative x 2
    • Like Like x 1
  18. soulevo8
    soulevo8 United States Active Member
    184
    94
    Indianapolis
    What @Bear said. Tork deleted both cats and had overboost issues. They are running a ported primary cat and their catless downpipes with no issues. They are also using an upgraded intercooler and piping which increased boost. It may be possible to go completely catless with stock intercooler and not overboost.
  19. Jonathan Lasich
    257
    87
    I'm looking at the ported driver's side primary cat, deleted secondary cats, and bimodal axle back exhaust but likely stick with stock intercooler as I live in a cooler climate. Looking forward to seeing Tork's final results. Should be eye opening!
    • Agree Agree x 1
  20. KLR STINGER
    432
    309
    68
    The overboost issue will not be a problem once tuning is completed. A 3" catted primary downpipe, to catless secondary plus catback will be the ideal setup once tuning is sorted.
    • Agree Agree x 1
Draft saved Draft deleted
Share This Page
