Vibration while backing?
Discussion in 'Engine, Drivetrain, and Exhaust Discussion' started by MekstingerGT, Dec 4, 2018.
  1. MekstingerGT
    MekstingerGT United States Active Member
    207
    86
    Anybody notice a little vibration while backing up? Its louder when backing on an incline and happens when you press on the pedal. It doesnt do it when you put it on reverse and just let the car back up on own.
  2. StungBlueGT2
    StungBlueGT2 United States Stinger Enthusiast
    758
    489
    68
    Florida, U.S.A.
    Do you have a GT2 with the LSD (Limited Slip Differential)? I hate to say it but it might be the rear differential issue that has become more common lately. My Stinger was one of the first to have it completely replaced in the USA and many people in Australia have similar issues.
    Try making a figure 8 or at least a tight u-turn while giving a little throttle. If it makes a whining noise, shutters, or you feel alot of drag its probably the LSD (Limited Slip Differential) and would take it to Kia Asap!
    Heres a thread about it and i have a few posts in there describing my situation.
    Broken Differential
    Hope you dont have the same issue and hope this helps
  3. Terra
    Terra Australia Active Member
    374
    107
    Australia Melbourne
    Yes it sounds like the LSD (Limited Slip Differential) problem.
    Contact the dealer and they should be replacing the diff oil.
  4. MekstingerGT
    207
    86
    Went throw all 4 pages of the thread. The symptoms might totally be different than mine. It's more vibration than sound. I also tried uturns and figure 8 no sound. I'm going to knock on would and hope it's normal. It's not crazy vibration and if it is it feels like its coming from the engine or transmission.
Draft saved Draft deleted
Share This Page
