[VENDOR][FS]: Kia Stinger - Stoptech Performance Front & Rear Ceramic Brake Pads - K8 Stinger Store
Paul @ K8 Stinger Store
Authorized Vendor
573
267
68
Raleigh, NC
Is proud to present to the Stinger community:
The Kia Stinger GT - Stoptech Performance - Front & Rear Street Ceramic Brake Pads
(BUY NOW)
Description:
Are you tired of the factory brake pads not being up to par for the performance that comes with the Kia Stinger? Well, look no further, as we have the perfect solution for you.
Choosing the correct friction formula for your Kia Stinger is essential for optimizing brake system performance and reliability
StopTech's engineering team carefully selects and tests each friction compound to ensure proper stopping performance, on both the street and track, throughout the lifetime of the brake pad
These ceramic pads are made with Para-aramid composites which provide linear response regardless of pad temperature
Specifications:
100% Asbestos-free formula
These brake pads are available in sets of: front pads only, rear pads only, or front & rear brake pads for the Stinger GT, depending on which set you choose before checkout
100% positive molded for uniform friction material density
Reuses the OEM Brembo hardware when installing the pads
Ceramic pads are scorched to raise the initial cold effectiveness & ease the bed-in process
Stoptechs low dust ceramic formula is rotor friendly & keeps your wheels cleaner for longer with less brake dust
Vehicle Applications:
2018-2020+ Kia Stinger 3.3T (GT Models Equipped with Brembo Brakes)
THANK YOU FOR LOOKING!
Uzurk
Any update on when the rears will be available?
