[VENDOR][FS]: Kia Stinger - Stolz Big Brake Kit - K8 Stinger Store
Daniel @ K8 Stinger Store
Authorized Vendor
Is excited to present to the Stinger forums:
STOLZ Big Brake Kit
(BUY NOW)
Description:
With over 30 years of experience in aftermarket automotive manufacturing, Stolz was established in 2003 to focus on high-quality brake component development
Addressing common issues found in the stock Stinger brake system, this big brake kit will significantly enhance your driving experience and stopping power
Stolz Big Brake Kits feature a monoblock lightweight 6-piston caliper, available in four color options: RED, SILVER, BLACK, and YELLOW
This kit includes patented 2-piece drilled floating rotors designed for excellent heat dissipation and reduced weight
High-quality reinforced brake hoses are included to prevent vapor locking and corrosion
Additionally, this kit comes with Stolz’s high-performance signature sport ceramic brake pads, matched explicitly for the Stinger
Stolz brake rotors undergo an extensive manufacturing process, including heat treatment up to 800°C (1472°F), ensuring they can withstand spirited driving
This Stolz Big Brake Kit provides shorter stopping distances, improved brake modulation, a firmer brake pedal feel, and less brake fade compared to the factory Brembo's
Specifications:
Brake Pads (4)
Rear Calipers (2)
Front Calipers (2)
2pc Lightweight Rotors (4)
All hardware included
Material: 1800T Forged Aluminum Alloy
Pistons: 6 total: (2x40mm, 2x36mm, 2x36mm)
1-year warranty through the manufacturer
Vehicle Applications:
2017-2020 G70 (All models)
*This kit is designed to replace the factory braking system on your Kia Stinger or G70,
and is a 1:1 replacement, compatible with all of the different trim levels for the models shown above
THANK YOU FOR LOOKING!
wow, looks nice!
Is it possible to get it without the brake lines?
Unfortunately, the kit is sold complete with all of the components shown on the product page of our site where the product is sold.
However, you can always keep an extra set if you don't need them, or sell them privately. The price for the complete kit is pretty competitive compared to other BBKs out there.
Are they bigger than the stock Brembos that come on the car
Absolutely, MUCH bigger!
Here are some pictures of them installed on our customers Stinger:
Notice how they fill up most of the wheel area inside?
These things are MASSIVE!!
Wow they look absolutely amazing. Great job and I def will be investing in these very soon. Btw will they fit under the stock Stinger 19 inch wheels?
Thank-you
Thank-you
Thank you, we think so too!
This is one of the few big brake kits on the market made specifically for this platform, that not only provide a direct 1:1 replacement, but that also provide superior braking abilities over just swapping the stock rotors and pads.
Yes, they fit perfectly with the stock Stinger 19” wheels.
Okay awesome : ) and exactly what size wheel is your customer running with the big brake kit from the pics you’ve shown? The fitment and size / style of this wheel make the brakes look amazing.
He is running 19x8.5 +30 offset ESRs & I agree, they look incredible with the Fella BBK installed with his wheel choice!
One last question is the actual fella caliper bigger than the shock Brembo? Are all the colors the same size caliper ? Wether it’s yellow red black orange blue are they all the same size?
I don’t mind answering any questions you have, there is also a lot of information on the product page of our site where we sell these.
The calipers are massive and definitely larger than the brembo calipers are. Yes, they are the same size, the color option will have nothing to do with the size of the calipers.
I've looked at these and with the bar that is casted with caliper that goes across the pads I'm assuming this is gonna be a "pull the caliper" just to change pads? I've gotten kinda accustomed to the brembos. Takes longer to jack the car up and pull the tire than it does to change pads. Lol
I personally have not changed the pads on a vehicle that is equipped with this BBK. However, I do not believe the process is any more tedious or difficult than changing the Brembo pads with the factory rotors and calipers.
Get the ultimate upgrade in braking with the Stolz Big Brake Kit.
This kit transforms your Kia Stinger into a stopping machine on the road or track.
We offer this kit in a variety of caliper color options to suit your Stingers styling needs.
The Stolz Big Brake Kit is designed to give you better brake pedal feel, less brake fade, and shorter stopping distances.
