Daniel @ K8 Stinger Store
Authorized Vendor
- Jul 16, 2019
Is proud to bring to the Stinger community
Seibon Carbon Fiber Hood Prop
(BUY NOW)
Description:
The days of using a broomstick to hold your hood or trunk open are over!
Seibon Carbon introduces the very FIRST and ONLY carbon fiber hood/trunk prop in the automotive industry.
This hood/trunk prop can extend up to 50’’ inches to provide as much clearance and “playing” room as possible.
The hood/trunk prop is made with the same high-standard that Seibon Carbon uses to make all of its products.
So you say, why can't I just use the same mechanism that holds open my Stinger's stock hood?
Carbon fiber hoods and trunks are usually much lighter in weight than their stock counterparts.
As a result, the shocks/dampers/struts/springs that are used with original metal pieces have stronger pressures than what's necessary for a carbon fiber piece.
Customers are advised NOT to use OEM mechanisms, because they may prevent your hood from closing & may cause carbon products to crack from over-pressure.
Specifications:
Manufactured by Seibon from the highest grade carbon fiber raw material available
6-month limited clear coat warranty from Seibon
Very nice attractive sleek & glossy finish
Vehicle Applications:
Universal (Works with all vehicles)
THANK YOU FOR LOOKING!
