Daniel @ K8 Stinger Store
Authorized Vendor
- Oct 24, 2017
Is excited to present to the Stinger community:
Eibach PRO-PLUS Kit
(BUY NOW)
Description:
Eibach PRO-Kit Lowering Springs & the complete Anti-Roll Kit for your Kia Stinger (PRO-Kit + Anit-Roll-Kit = PRO-PLUS Kit)
The Eibach lowering spring kit for the 2018-2023 Kia Stinger, improves your vehicle's looks and performance
Lowers your center of gravity, reduces body roll, & gives the car a solid & secure feeling at all times
The Front/Rear Sway Bars affect the handling on the lower end of your Kia Stinger suspension
Thicker construction keeps your car flatter in turns when cornering by decreasing body roll
Front & Rear Sway bars are tubular solid construction & have a two-way adjustment
Specifications:
Includes 1 set of (4) lowering springs + front & rear adjustable sway bars
Rear Sway Bar Thickness: 19mm/Front Sway Bar Thickness: 25mm
Easy to install and are a direct replacement
Drop Height: 1.4” Front/1.2” Rear
1 Million-Mile warranty by Eibach
Vehicle Application:
2018-2023 Kia Stinger (All models)
THANK YOU FOR LOOKING!
