1. We're having a vote for the location of our upcoming KIA Stinger dot com StingerFest. Please CLICK HERE to cast your vote!
[VENDOR][FS]: Kia Stinger 3.3T - Ultimate Performance HFC Downpipe + Mid Pipe Kit - K8 Stinger Store
Discussion in 'Performance Products' started by Paul @ K8 Stinger Store, Sep 10, 2018.
  1. Paul @ K8 Stinger Store
    Paul @ K8 Stinger Store United States Stinger Enthusiast Authorized Vendor
    549
    252
    68
    Raleigh, NC
    • Like Like x 1
  2. ChiTownStinger
    ChiTownStinger United States Active Member
    122
    57
    Chicago, IL
    Interested to hear more on this from someone who has it installed.
  3. Anarchy99
    Anarchy99 United States Member
    66
    7
    Same here....I wanted to buy it but $1400 with no dyno to show us what the potential is or even track times, no clear indication if you will get overboost codes without a tune.
    Sound clips sound really good though.
    Want to see how this progresses.
  4. ChiTownStinger
    122
    57
    Chicago, IL
    Where are the sound clips?
    • Agree Agree x 1
  5. Anarchy99
    66
    7
    Hit up the Stinger Owners Facebook page, he has some rev videos. Type in Ultimate Performance.
  6. WildBill
    WildBill United States Active Member
    378
    132
    Central NY
    Yeah, the clip sounded amazing. You won't want a muffler delete and this installed!
    From my understanding this kit removes the factory primary and secondary cats, replaces them with high flow cats and runs the piping down to the point at which a typical cat back exhaust would hook up.
    Most have been calling the pipe between the primary cat and the exhaust the downpipe and the section between the downpipe and the axle area as the midpipe.
    Just need to clarify the terminology.
    I think this description will mess a lot of people up.
    • Like Like x 1
  7. DaJackson
    DaJackson United States 1000 Posts Club! Staff Member Moderator
    1,412
    551
    Louisiana
    Still not sure why this is $1500
  8. WildBill
    378
    132
    Central NY
    My guess is the premium for replacing the 2 cats with single high flow varieties.
    They are first to market.
  9. DaJackson
    1,412
    551
    Louisiana
    First to market I’ll agree with but charging more for downpipe a than most catbacks is crazy talk to me.
    I’m waiting on the SSR secondary delete to ship so I don’t have to worry about overboost codes. Someone will come out with a more reasonably priced primary delete with testing to back it up soon.
    • Agree Agree x 1
  10. STINGER
    STINGER Bahrain Stinger Enthusiast
    502
    243
    Bahrain
    Good HFC's do cost a lot, and they seem to have used ones with 6" maybe even an 8" body which is more than your typical 3" that most use, so they must be expensive. Typically downpipes with dual HFC's go for $1,500+, so the price for this I think is reasonable.
    My only grip is that they didn't go with a cast wide mouth inlet that is shaped exactly like the turbo outlet, even though it is 2.4" at the inlet it will still have areas that will block and cause turbulence.
    • Agree Agree x 1
  11. Jonathan Lasich
    Jonathan Lasich Canada Active Member
    282
    89
    I agree!
    So, how many hours figured for install time?
    Does the engine have to be dropped to install the primary downpipes?
    This must be good for an additional 50 HP with proper tuning, I would imagine?
  12. Paul @ K8 Stinger Store
    549
    252
    68
    Raleigh, NC
  13. Jonathan Lasich
    282
    89
    So, with the O2 sensor non fouler installed, if there is no tune on the car, i assume no CEL or other warning lights illuminated? I'm planning on an ECU tune with a spare ECU, so for service at the dealer put the OEM ECU back on the car so no indication of a tune on the car. I'm thinking about when we take the car back to the dealer for service. No issues that would alert the service tech that something is amiss?
    • Like Like x 1
  14. Paul @ K8 Stinger Store
    549
    252
    68
    Raleigh, NC
  15. Jonathan Lasich
    282
    89
    That's OK. Them being installed doesn't bother me. Detecting an ECU tune would be a problem. As long as the dealership thinks that the only mods are the downpipes (if they check) and nothing else, I should be OK. The dealership is mod friendly.
    • Like Like x 1
  16. Paul @ K8 Stinger Store
    549
    252
    68
    Raleigh, NC
  17. Oryan
    Oryan United States Active Member
    167
    38
    1400 for two big, quality magnaflow cats isn't crazy. It's about in line with a lot of other platforms and assuming design and quality is there is a perfectly reasonable price. Can't wait to see these on a dyno.
  18. STINGER
    502
    243
    Bahrain
    The overall price $1,400 considering that they are using MagnaFlow HFC's and that it is basically both down-pipe and mid-pipe is a good deal.
    You get what you paid for at the end, as MagnaFlow HFC's and the like (SLP, Flowmaster etc etc) don't flow as good or last as long as the higher quality (and more expensive) HFC's such as the German made HJS when used in high performance turbo applications. Cars that are tuned and run higher EGT's will give the HFC a hard time and many using the lower quality HFC's have reported melting them or rattling due damage etc. I would say the second best available HFC's are made by GESI (Vibrant).
    I personally would have liked to have seen this with 200 CELL HJS HFC's and a widemouth (bellmouth) design at the turbo flange for maximum flow, definitely with the HJS HFC's it will be closer to the $2k price range which I will be happy to pay as I have used HJS HFC's before, they will outflow and maintain better cleaning quality and outlast any HFC out their.
    • Like Like x 1
    • Agree Agree x 1
  19. Jonathan Lasich
    282
    89
    This I would like to know!
    • Like Like x 1
  20. Paul @ K8 Stinger Store
    549
    252
    68
    Raleigh, NC
    • Like Like x 2
Draft saved Draft deleted
Share This Page
