Daniel @ K8 Stinger Store
Authorized Vendor
- Jul 16, 2019
Is excited to present to the Stinger forums:
GiroDisc Brake Rotors
(BUY NOW)
Description:
Enhance the stopping power of your Kia Stinger with Brembo brakes, by installing these 2-piece GiroDisc Brake Rotors
Girodisc Rotors are crafted from an exclusive cast iron blend that is poured in the US & then expertly machined in-house by GiroDisc
GiroDisc Rotors have a floating mount system that employs high-strength alloy steel pins to bear the load from braking & simultaneously maintain float
Each rotor has multiple curved vanes that act as a centrifugal pump that forces cooler air through the disc allowing you to drive more aggressively for longer
In order to keep the rotors from making noise when cold, the pins are mounted with anti-noise spring washers on the rotor side which allow the rotor to grow with heat expansion but eliminate the rattle and noise associated with floating rotors
Features:
Manufactured by GiroDisc in the USA
2-piece floating rotor and hat mount system
6061-T6 aircraft specification aluminum hats
Low noise rotors due to anti-noise spring washers
Cadmium plated for a long-lasting corrosion resistance
48 curved directional vanes that act as a centrifugal pump
Option to choose either front (2), rear (2), or complete set (4)
Vehicle Application:
2018-2023 Kia Stinger (3.3T Models Only)
THANK YOU FOR LOOKING!
