Daniel @ K8 Stinger Store
Authorized Vendor
- Oct 24, 2017
Is excited to present to the Stinger forums:
DBA 4000 Series T3 High Performance Brake Rotors
(BUY NOW)
Description:
DBA 4000 Series T3 High Performance Brake Rotors are engineered to deliver consistent braking, improved heat management, & reduced vibration compared to OEM.
Designed for daily-driven and performance-oriented Kia Stingers, these rotors provide reliable stopping power under normal driving and aggressive conditions.
Precision manufacturing helps promote even pad wear, smoother braking feel, and long-term durability.
Ideal for stock vehicles or those paired with upgraded brake pads.
Features:
Available as front (2), rear (2), or complete front & rear set (4)
The 4000 Series T3 includes a high-carbon alloy construction for superior heat resistance
T3 bi-directional slot design promotes even pad wear and consistent bite
Compatible with OEM and aftermarket performance brake pads
Vehicle Application:
2018–2023 Kia Stinger (3.3T Models Only)
THANK YOU FOR LOOKING!
