[VENDOR][FS]: Kia Stinger 3.3T - BMS V2 Transmission Oil Cooler - K8 Stinger Store
Daniel @ K8 Stinger Store
Authorized Vendor
Is excited to present to the Stinger forums:
(BUY NOW)
Description:
Battle the heat and tackle performance with the Burger Motorsports V2 Transmission Oil Cooler
This is a plug & play kit that has a high-capacity heavy-duty front mounted air to transmission fluid radiator
The BMS Transmission Oil Cooler reduces transmission fluid temperature, dissipates excess transmission fluid heat, and increases oil capacity
With more performance comes more heat, capture all of your car's potential by finding solutions like this oil cooler to keep temperatures at a more optimal heat range
This latest version 2 transmission oil cooler is not only larger than the original upgrade but also connects directly to the factory coolant lines for an easier installation
Professional installation is recommended
Vehicle Application:
2018-2023 Kia Stinger 3.3T
2018-2023 Genesis G70 3.3T
THANK YOU FOR LOOKING!
Do you drive your Stinger competitively or visit the track often?
The Kia Stinger offers less than sufficient cooling from the OEM Transmission Oil Cooler
By adding this BMS V2 Transmission Oil Cooler, you will notice more efficient cooling and better performance
This must-have kit is a plug & play product that has a higher capacity heavy-duty front mounted air to trans fluid radiator
(CLICK THE IMAGE BELOW TO MAKE A PURCHASE OR TO FIND MORE INFORMATION)
