kia stinger store
[VENDOR][FS]: Engine Oil Cooler Kit with Secondary Radiator - K8 Stinger Store
Paul @ K8 Stinger Store
Authorized Vendor
563
261
68
Raleigh, NC
Is excited to present to the Stinger forums:
The Kia Stinger 3.3T - Engine Oil Cooler Kit with Secondary Radiator
(BUY NOW)
Description:
Many already know that the Kia Stinger 3.3T does not feature the most efficient oil and coolant cooling capabilities for hard street driving in hot weather, let alone for track or competition use. By adding this oil cooler kit with the secondary radiator kit for coolant cooling, you'll notice more efficient cooling, increased reliability and better performance all around out of your Stinger.
The kit is plug & play but does require holes to be drilled in the metal bumper to mount the radiator brackets.
Adapter connectors included to easily connect both the engine oil cooler and the secondary coolant radiator.
Kit includes cooler core (Pictured in silver), adapter, oil lines, and brackets.
Secondary radiator included (Pictured in black)
Professional installation is recommended
Vehicle Applications:
2018-2021 Kia Stinger 3.3T
THANK YOU FOR LOOKING!
Daniel @ K8 Stinger Store
Authorized Vendor
601
183
Looking for ways to improve your Stingers performance on track day?
Our plug and play engine oil cooler kit with an included secondary radiator is a great option.
This kit includes adaptor connectors, cooling core, oil lines & mounting brackets
Oil cooler kits are essential for colder engine temperatures during longer drive durations
This kit is incredibly helpful if you want to extend your enjoyment time out on the track, drag strip, autocross event, or any other spirited driving scenario.
Grab yours today or reach out to any member of our team if you have any questions at all about this Engine Oil Cooler Kit or any other product that we sell.
ddaversa
16
Is this system temperature-controlled? Here in Montreal, QC, Canada, the temperature sometimes drops as low as -40° (C/F) in the winter, so I'm afraid this could be a double-edged sword. If it isn't, would it be easy to, say, bypass in the winter & connect in the summer?
Authorized Vendor
601
183
Temperature controlled? No, this is a simple oil cooler kit and secondary radiator to help keep the oil cool.
Yes, I am sure you could set it up to bypass easily if you wanted to.
Authorized Vendor
601
183
Are you a competitive driver or track-focused Stinger owner?
Did you know that the Stinger has an ineffective cooling system when it comes to hard-driving scenarios?
By adding this Engine Oil Cooler with a Secondary Radiator you will notice more efficient cooling and better performance.
This must-have kit has an easily installed adapter to connect the engine oil cooler to the secondary radiator and is plug and play.
(CLICK THE IMAGE BELOW TO MAKE A PURCHASE OR TO FIND MORE INFORMATION)
