[VENDOR][FS]: 2018-2021 Kia Stinger 2.0T - Jun Bl GT Catback Exhaust System - K8 Stinger Store
Brendan @ K8 Stinger Store
Authorized Vendor
Los Angeles, CA
Is excited to present to the Stinger forums:
(BUY NOW)
Description:
The Jun Bl GT Catback Exhaust System for the Kia Stinger 2.0T is a 100% perfect bolt-on system that requires no modification or welding at all
This replaces the OEM exhaust directly & squeezes all available horsepower from your 2.0T Stinger engine while also increasing torque
Jun Bl's exhaust design produces a deep growling & aggressive sound all the way up through redline
Truly among the best exhaust systems on the market for the Kia Stinger
Vehicle Applications:
2018-2021 Kia Stinger 2.0T (All Trims)
2018-2023 Kia Stinger 3.3T:
(FOUND HERE)
Additional Information:
True quad-outlet dual exhaust which fits with stock exhaust tips
Dyno-proven +11.4 horsepower at 4400 rpm & +1.5 torque at 3400 rpm
Polished stainless steel construction (SUS-304)
All hardware necessary for install included
Professionally TIG-welded, 3D bending
Mid pipes size: Φ54x2 mm
Inlet pipe size: Φ65x2 mm
CNC-machined flanges
THANK YOU FOR LOOKING!
Installed this exhaust about a month ago and immediately noticed a few things that are still apparent after 1 month of daily use.
Just FYI I also have JB4, intake & HKS spark plugs. 91 gas, used both map 1 & 6. (6 had better results after playing with it for a while)
Gear Shifts
- the switch between the gears is a lot smoother. I used to feel every gear switch with the stock exhaust because of the kick it had, now driving the car feels more relaxed.
(Again I think this is because the car is no longer building up the air and burping it out)
Sound
- car is definitely louder and sounds just like the video, it loudest during take offs in the lower gears or when you start the car but then the noise fades. As you drive down the road you can barely hear it if your in another car or with the windows rolled up. Putting the car in neutral quotes the car even further. If you drive the car at a higher gear the exhaust becomes much more noticeable and can be heard by other drivers around you.
Are you trying to squeeze every bit of horsepower out of your 2.0T?
The Jun Bl GT 2.0T Catback Exhaust is one of the best upgrades available for your Kia Stinger.
Made from the highest quality steel and optimized for maximum performance gains.
This true quad-tip exhaust produces an incredible, deep growling and aggressive tone.
(CLICK THE IMAGE BELOW TO MAKE A PURCHASE OR TO FIND MORE INFORMATION)
