kia stinger store
Useful Products for your Stinger on eBay and Amazon
Staff member
8,153
2,777
Palm Beach, FL
We're up to about 400 posts per day and it's easy to lose track of where that item was you wanted to buy. I'm going to start a list of products you may find useful with a link to where you can buy it on eBay and/or Amazon. If you see a product that you feel would be useful to our audience, please post a reply and I'll update this message...
If any of our vendors would like to replace a link here to one at their website, please let me know...
Vertical cargo net for the hatch: (Canada)
Aluminum Handle Inside Door Catch Plate 4 pieces (LED lit)
LED Door Scuff Inside plate
Felt Inside Door Shields/Covers Scratch Kick Protector (set)
OEM 2018 Kia Stinger RWD All Weather Rubber Floor Mats
Aluminum Console Cup Holder Inside Plate 4 pieces (LED lit version)
Kia Stinger 3.3L K&N Turbo Typhoon Air Intake
Rear Glass C Filler Mask Sports Plate Molding
Stinger Text Stainless Steel Door Striker Cover 4 pieces
Smart Keyless Entry Proximity Remote Key
OEM Side Wing Air Flow Fender Intake Vent Trim
OEM Air Flow Intake Hood Bonnet Vent Cover
M&S Front Splitter Lip
M&S Side Splitter (Side Skirts)
M&S Wing Type 2 Piece Rear Lip Set
M&S Rear Diffuser
Mud Guards Front & Back Accessory Kit
Metal Sticker Silver Emblem Badge
Head Light Lamp Eyeline Lid Molding
Carbon Door Decal Sticker Cover Kick Protector
Rear Bumper Reflector 3 Way Turn Signal LED
Cup Holder Bottom LED Light
iOttie Easy One Touch Qi Wireless Fast Charge Car Mount for Samsung Galaxy S8, S7/S7 Edge, Note 8 5 & Standard Charge for iPhone X, 8/8 Plus & Qi Enabled Devices
Universal 360 Degree Rotating Phone Holder Car Magnetic Mount Stand Cell Phone | eBay
BODY SIDE Moldings, PAINTED With CHROME Trim Insert For: KIA STINGER 2018-2019 | eBay
BODY SIDE Moldings, PAINTED Trim Mouldings For: KIA STINGER 2018-2019 | eBay
Reverse and License plate bright white LED lights:
https://www.amazon.com/Philips-1278...ot-20&linkId=0bc1b2a32f53e7b18055d319b667a418
NEW PHILIPS ULTINON 921 WHITE LED 12 V BULBS 921ULWX2 Pack of 2 | eBay
Drop Stop - The Original Patented Car Seat Gap Filler (different version with pockets)
SEA Stinger
276
68
Seattle, Washington
Genuine OEM Side Wing Air Flow Fender Intake Vent Trim For 2018 2019 kia stinger | eBay
I'm thinking about ordering these to replace the brake vent covers on my Snow White Pearl Premium 2.0t Stinger. These are smoked chrome, which I think will look better than the silver-colored ones that are on the vehicle. However, not sure about how to remove the existing covers. Has anyone already made this kind of change-out? If so, was any special technique or tool required? I don't want to try just brute-force yanking the existing ones off if that will damage my new baby!
Staff member
8,153
2,777
Palm Beach, FL
Have you felt around inside for bolts? If you don't feel anything, they're probably on the opposite side of the panel. You shouldn't need to rip them off. :p Just unscrew them...
Chris
284
68
MN
Look at the pics in that link. They look like they just snap on to me. If you buy them and have them in your hand it should be really obvious how they connect. That will tell you how to remove them. :geek:
SEA Stinger
276
68
Seattle, Washington
At first, I thought the screws might be used to mount the cover to the side of car. But based on a closer look it does appear that there are snaps that allow it to be installed by pushing the cover into the side of the car. At this point, my main question has to do with how to remove the existing cover so that I can replace it. Anyone have suggestions?
Chris
284
68
MN
Its got to come off the opposite way it goes on. Grab on and pull. Might need a plastic tool to pry it a little..
SEA Stinger
276
68
Seattle, Washington
Ok, thanks. I will get a plastic pry tool then hold my breath, pull and hope for the best. Might take a day or two, but will report results when I try this.
corradoMR2
303
68
GTA
I like this and might order it. Low risk cost if it turns out to be tacky.
Note though this might not work for US folks since the decals at the rear are made for heated-seats (per the pics).
SEA Stinger
276
68
Seattle, Washington
http://amzn.to/2DwTMAl
corradoMR2
303
68
GTA
I will quote my own post.
The vinyl won't work for Canada either since the front right door vinyl has only one hole for the power window switch and oddly not for the door lock (Does the Korean Stinger have the power door lock in a different location??)
westcoastGT
5000 Posts Club!
6,969
2,784
Vancouver , Canada
I
I Dont think prying it off is the way to remove it , I wanted to cover the skid plates on my X6 with Viny and tried several things to remove them without luck . Then I just asked my BMW service advisor how to remove it and it was simply pulling it forward to release the "snaps .You dont want to risk damaging your car , your dealer will have access to the proper process as will a good autobody shop . Also I was going to suggest painting the vents or wrapping them . The orange Sema car had those pieces wrapped in Carbon Vinyl and it looked good ( if youre going to all the work to remove them , Customize them !!
just my$.02
jongkihong
Authorized Vendor
132
74
South korea
[따옴표 = "바다 침착 물, 포스트 : 21582의 일원 : 1541"] 2018 2019를위한 진짜 OEM 측 날개 공기 흐름 펜더 입구 통풍 손질 kia stinger | 이베이
나는 Snow White Pearl Premium 2.0t Stinger에서 브레이크 벤트 커버를 교체 할 것을 주문하고 있습니다. 이것들은 훈제 크롬입니다, 나는 자동차에있는 은색 색깔의 것들보다 더 좋게 보일 것이라고 생각합니다. 그러나 기존 덮개를 제거하는 방법에 대해서는 확실하지 않습니다. 이미 이런 종류의 변경을 한 사람이 있습니까? 그렇다면 특별한 기술이나 도구가 필요 했습니까? 그게 내 새 아기에게 피해를 입히려면 기존의 것들을 꺼내려고하는 것뿐입니다! [/ QUOTE]
