Transmission slips to Neutral by itself when driving
Discussion in 'Engine, Drivetrain, and Exhaust Discussion' started by Kia Stinger, Feb 24, 2018.
  1. Kia Stinger
    Kia Stinger United States Administrator Staff Member
    6,308
    2,022
    Palm Beach, FL
    This message was intended to be posted by @CrisX but accidentally landed elsewhere...
    A new issue surfaced recently with my Stinger GT. It happened a few times the past couple weeks but it was not that serious -- after i started the car and put it into Drive (dash showed D) and the car just started rolling, the transmission slipped to Neutral by itself and I have to put it back to Drive again. All were good afterward.
    Today, the same situation happened after the car was already running for 2 to 3 minutes. All of a sudden the engine was free revving and the car was slowing down. I noticed from the dash that the transmission was in N. It was no doubt a scary moment given that I was driving at 80 km/h at the time with quite a bit of traffic around me. Luckily I could put it back to Drive without any hiccup. It did not re-surface for the rest of the trip.
    Did anyone experience similar issue with the transmission? I also have other issues (ISG (Idle Stop and Go), Apple Carplay/USB port) and am wondering if there's an electrical gremlin hiding in my car.
  2. MikeyCanuck
    MikeyCanuck Canada Active Member
    159
    83
    Sturgeon County, AB
    5700+ km in... no such experience for me...
  3. Terra
    Terra Australia Active Member
    375
    107
    Australia Melbourne
    Interesting....................4200km also haven't had that happen.
  4. DaJackson
    DaJackson United States 1000 Posts Club! Staff Member Moderator
    1,194
    469
    88
    Louisiana
    To clarify when you say it goes into N and you have to put it back into drive, is it...
    A) The dash shows N and the shifter is in N so you have to move the shifter back into D
    Or
    B) The dash shows N but the shifter is in D so you have to move the shifter to N then back into d
    • Like Like x 1
  5. Marc Collins
    Marc Collins United States Stinger Enthusiast
    683
    86
    Toronto, ON
    I will guess it's the electronic shifter (drive by wire) that doesn't have physical positions relating to the mode...
  6. Freelancer
    Freelancer United States Member
    37
    12
    Tinley Park, IL
    What model do you have?
  7. Bear
    Bear United States Active Member
    269
    129
    Northern Virginia
    I have GT2 (shift by wire) and have not experienced any issue like this. Have 2k miles on the car.
  8. eflyguy
    eflyguy United States 1000 Posts Club! Staff Member Moderator
    1,907
    678
    Georgia, USA
    That was my first thought as well, but he states "GT" so I'm assuming not.
  9. Freelancer
    37
    12
    Tinley Park, IL
    I never make assumptions. DbW can be touchy, if he has a GT2, it might be a problem.
  10. Chris
    Chris United States Stinger Enthusiast
    784
    272
    68
    MN
    The OP is in Canada. Im pretty sure both the GT and the GT limited (the only two models in Canada) are shift by wire.
  11. BIGRED
    BIGRED Canada Active Member
    Yes, you are right. Canada has only AWD models in GT and GT LTD trims, and both are shift by wire.
  12. corradoMR2
    corradoMR2 Canada Active Member
    314
    285
    68
    GTA
    2500 kms on mine. No issues. Sorry to hear about yours. Definitely get it checked out.
    • Like Like x 1
    • Agree Agree x 1
  13. djfosfor
    djfosfor Kazakhstan New Member
    2
    0
    1
    Hello. Sorry in advance. my English is very bad. I on Russian forum wrote. and I was the only one with that problem. Exactly the same problem ! 1 in 1 . gt line.
    3 times already so it was. I almost got into an accident. I was speeding out of the turn. the car abruptly stopped to pick up speed and shifted into neutral. I have 13000km mileage. All 3 times I was accelerating out of a turn. You have the same situation or you on a flat road went?
    Have you learned anything during this time ? Are you sure you didn't touch it ? Because the Official dealer assures me that I hurt myself .. did diagnosis. There are no errors. Everything's fine...
  14. NS_Stinger
    NS_Stinger Canada Stinger Enthusiast
    522
    126
    Guys that this is happening to, was your hand resting on the shifter when it happened? Im just curious if you inadvertantly could have slipped it into neutral by accident.
    • Agree Agree x 1
  15. djfosfor
    2
    0
    1
    I believe that there is no, because I keep hand on the armrest. Waiting for next time ...
  16. Kazz
    Kazz United States 1000 Posts Club! Texas Stinger Swarm
    1,248
    429
    88
    Illinois
    The only time I've heard of this is when the shifter is bumped or someone is resting their hand on the shifter (I've done it once myself). If you're confident it's not being touched, I'd talk to my service department.
    Good luck!
  17. Audible Silence
    Audible Silence United States Active Member
    181
    19
    if its fairly common, maybe try catiching it on video with cell phone
Draft saved Draft deleted
Share This Page
