twelvexes
- Jun 8, 2019
i'm planning on getting the ace AFF02 wheels, 20x9 fronts/20x10 rears. the shop i work with is recommending 235/35/20 front tires and 265/30/20 rear tires. i want that beefy look and am not sure this combo will give me that, especially out back. i was thinking of going with 275/30/20 rear tires instead. the shop doesn't want to go a full inch larger than the oem diameter as they want to be 100% sure they won't rub. they believe these would work, but are admittedly playing it safe. however, i see a lot of stingers running considerably larger set ups.
looking for opinions. i have a '19 GT AWD with ark springs.
these are the numbers from tire rack...
front tires:
stock - 225/40/19 = 26.1"H x 8.9"W, Sidewall 3.5", Diameter 26.1"
shop suggestion - 235/35/20 = 26.5"H x 9.3"W, Sidewall 3.2", Diameter 26.5"
rear tires:
stock - 255/35/19 = 26"H x 10"W, Sidewall 3.5", Diameter 26"
shop suggestion - 265/30/20 = 26.3"H x 10.4"W, Sidewall 3.1", Diameter 26.3"
my suggestion - 275/30/20 = 26.5"H x 10.8"W, Sidewall 3.2", Diameter 26.5"
front tires:
rear tires:
