Strange, mine's been spot-on. Overnight cold, I inflate to 36, flip the display for tire pressures, drive past 35MPH and each tire pressure pops up at 36. However, what I have noticed is more down to physics: the tire pressures start to increase very unevenly until they all ready operating temperatures around 38-40psi. What I mean by physics is a few things: the weight distribution is not perfectly centered between the tires, so even though the car is 52/48 front to back, the left to right may be different; if your drive has more right turns than left, your driver's side tires will start heating up first, etc. However, I've never seen a car where the tires heat up at such rapidly different paces until they all reach operational temperature. The vehicle seems to inherently have a little more weight on the passenger side than the driver's side (which makes sense when you add a driver) from what I can surmise observing my tire pressures as they heat up.
