Stinger43 Member Joined Nov 18, 2020 Messages 64 Reaction score 67 Points 18 Location Canada Feb 5, 2021 #1 In my manual section 6 page 23 (Canada) under flat tire section they are saying if you have a flat tire with tire mobility kit (if equipped) ? My 2021 it's limited version anyone do have this kit? I don't?
H hayagix Active Member Joined Oct 15, 2020 Messages 136 Reaction score 85 Points 28 Feb 5, 2021 #2 Mine did not have a kit. I made my own: Tubeless tire repair strings. Reamer tool. Installer tool. 12 volt compressor. Tire gauge. Exacto knife blade(to trim strings after install). A small puncture is easier to fix than to change the tire. That is if the tire bead has not unsealed from the rim. String fixes are temporary.
RedCal 2500 Posts Club! Joined Jan 2, 2020 Messages 3,227 Reaction score 2,059 Points 118 Location Toronto, ON Feb 5, 2021 #3 Good idea! A pair of needle nose vise grips might be a good addition in case there is a nail or screw in the tire that needs to be removed
