SWITCH FUSE FOR SUBWOOFER
nv_stinger
I am having trouble finding a fuse to use for my subwoofer, since I am now using the 30A ACC fuse in the rear for my air suspension.
What other switch fuses can I use? By switch fuse, I mean the ones that are only "ON" when the car is turned on.
Not sure if any of this matters but....
Here is the model of my car:
2022 Kia Stinger GT-Line RWD
Here is my Audio setup:
Sundown Audio E12 SUB - 31 Hz - 1 OHM
Down4Sound JP8 | 800+ wRMS Car Amplifier
Audio Control LC2i PRO 2-Channel Line Output Converter
Thanks,
Use the remote out from the LC. Turn the switch to "GTO" if that doesn't work turn it to "Audio". I recommend starting with "GTO" first.
