3.3TT Stumble on hard acceleration
Discussion in 'Engine, Drivetrain, and Exhaust Discussion' started by StingerGTT, May 13, 2018.
  1. StingerGTT
    StingerGTT United States Active Member
    135
    53
    So I'm sure this subject has been covered in some way shape or form I have a GT 3.3K on it and sometimes not all the time it stumbles on a hard acceleration I'm sure its a misfire I have not got a CEL nor is the car chipped YET my question is has anyone found a permanent fix to this yet?? Is the dealer taking care of this for us ?? are they going to use better plugs in the car to fix this issue ?? Any info would help me greatly without berating me and saying things like if you knew how to hit your gas pedal 2mm to the left this wouldn't happen . lol Thank you everyone
  2. Kamauxx
    3,177
    1,255
    You should take it in to the dealership. Have them check to make sure the plugs aren't damaged. If they are they'll replace them with the same plugs gapped at .036 ish.
    The general consensus is that with or without a higher boost tune the plugs should have a smaller gap, so if the dealership says the plugs are fine it might be a good idea for you to re-gap them at home.
    I've gapped mine to .025 to use with BMS's JB4 on map 2 (+4psi) and have had no problems with it.
    Oh yeah, one more thing. If you weren't hitting the gas pedal so far to the left you'd be fine. :p
    • Funny Funny x 3
    • Agree Agree x 2
  3. StingerGTT
    135
    53
    So you re-gaped the factory plugs on a tune ? You didn’t pay the rediculous price for HKS plugs ? Thankyou for the input greatly appreciated.
  4. Kamauxx
    3,177
    1,255
    Yes I just regapped the stock plugs.
    If you look in the tuning forum there's a thread about spark plugs stickied to the top. In there is a wealth of information from a few very knowledgeable forum members.
    • Informative Informative x 1
  5. TwistedOrca
    TwistedOrca United States Active Member
    Mine pulls the same miss feeling under load, plan on taking it to the dealership. Reading the forum, looks like these plug/gap issues are solved at home.
  6. Fl stingergt
    Fl stingergt United States Stinger Enthusiast
    567
    86
    What spark gap we using with hks plugs. Stock 35 ish. Give me that good info guys
  7. Johnny B
    Johnny B Canada Member
    40
    44
    I find this only happens when I have both traction control and stability control disabled. There was an article where they were testing the drift abilities of the AWD model and found that with both of these functions disabled a torque limiter kicked in under hard acceleration and forced the transmission to shift to second gear.
    • Agree Agree x 1
  8. Fl stingergt
    567
    86
    These are learning transmissions . When I got mine and drove in manual mode with everything off. It would shift still on own at high rpm. After a few weeks of driving mine stays in gear but if you don’t shift quick enough fuel is shut off to engine at 6500 rpm and car just falls on face. The car shifts quick enough in auto
  9. Beege
    Beege United States Active Member
    196
    170
    You're holding it wrong??
  10. StingerGTT
    135
    53
    Lol I just realized that last comment Kam lol I figured someone would say something like that in a non joking way so I got it over with for them lol thanks for all the help though guys the dealer will gap them at what I tell them to, cleared it up today with them. now I just need the time to get it done.
    • Like Like x 1
  11. Beege
    196
    170
    Hmm maybe I can get the dealer to regap mine for me...
  12. StingerGTT
    135
    53
    I know the service manager very very well he knows I know what I'm doing and trusts my judgement not all dealers may allow this just be cautious on what you say a lot of dealers are foaming at the mouth to void your warranty just a word of advice but good luck !!!
  13. StingerGTT
    135
    53
    actually had a tech loose his shit when he got curious and looked under my hood without me knowing and then returned with he car after a "test drive" to see my BOV venting atmospherically and when he returned first words where " your gonna void you warranty doing that stuff watch out " my response was "doing what ? the BOV mod ? it has nothing to do with any crucial sensor in the engine management system so you should maybe go back to class son" The service manager intervened just in time before I sent the " tech" back to class and told the tech " he knows what he's doing go back in the shop please" lol
    • Like Like x 2
    • Funny Funny x 1
  14. Sabz
    Sabz United States Active Member
    336
    48
    FARMINGTON MN
    So I’m wondering if I have a problem... I don’t get any codes but the car feels like a dog sometimes when I step on it. Do you think it could be my plugs? I would at least think I would throw a code right ? I really don’t know much about working on cars
  15. StingerGTT
    135
    53
    I don’t get a check engine light either but it’s clearly the plugs missfireing for a few seconds on hard acceleration
  16. Fl stingergt
    567
    86
    Run 93 octane
  17. Sabz
    336
    48
    FARMINGTON MN
    You think that will solve it? My last tank was 93 and you may be right because I notice it now with 91... even though it’s a small difference
  18. Tonkabob
    Tonkabob United States 1000 Posts Club!
    1,137
    523
    Seattle, Wa
    @Sabz and @stingergt@stingergtt are you both stumbling on initial hard acceleration or high RPM WOT. Sounds like initial. I have the HKS smaller gapped plugs and have stumbled on initial acceleration once. Plugs fix high rpm which i have never encountered.
    Interesting comment above about torque limits and shifting into second as thats what mine felt like.
  19. Johnny B
    40
    44
    It is not a misfire. I am using gapped plugs at .024 and 94 octane fuel. Ecu nannies kicking in. If you feather the throttle instead of mashing it down I find it eliminates the hard cut.
  20. Johnny B
    40
    44
    • Like Like x 1
Draft saved Draft deleted
Share This Page
Users found this page by searching for:
  1. c43 v kia stinger
  2. 2007 kia stumble on acceleration
