Staggered Tires & Replacement
Forby
Howdy all,
Relatively new 19 GT1 owner, first vehicle I've ever owned with staggered Tires. Are factory wheels same size for both axles? When the time comes for tire replacement would I be able to mount 4 same size ones so I can rotate? Or will different wheels be necessary?
OE 19" wheels are 8" wide in front, 8.5" wide in the rear. You only "rotate" side to side. That's what "staggered" means. To go square you'll need the same wheels all around.
