SSR down pipes + Thermal cat back = DRONE
Discussion in 'Engine, Drivetrain, and Exhaust Discussion' started by Andimal, Nov 8, 2018.
  1. Andimal
    Andimal United States Member
    78
    15
    Crossville, TN
    Hey all,
    I just had SSR down pipes and Thermal catbacks installed. There is A LOT of drone when on the gas between 1800-2300rpm or so. I picked the thermals because of the tame note and lack of drone, according to reviews.
    So my question is: is the drone being created due to the down pipes in addition to the catbacks? What are some ways to help the situation? Resonators? Anyone else running this same setup?
    Thanks!
  2. Socalstinga
    Socalstinga United States Active Member
    351
    84
    I'm running the same set up. I got the thermals on first for about 5k miles and then the jun bl dps (on for a few weeks now). that 1800-2300 rpm range your talking about, I've experienced that since I got them installed, usually the resonance in that range I experience while light acceleration and wouldn't necessarily call that drone. semantics aside, it quieted down quite a bit when I installed some sound deadner in the spare tire area (road noise reduced substantially btw). Then I installed the dps and although louder, it wasn't as intense of a resonance as when I initially installed the thermals by themselves and prior to the sound deadner.
    Some have suggested to either get some new resonators or use the old ones from the stock setup. Another option would be to sell the thermals and throw the stock mufflers back on. you get the performance aspect of the DPs plus a little more growl without the deep bassy sound of the thermal (which I think is one of the bigger reasons for the resonance) I may do that eventually, but I would just cut the thermal muffler off and sub the stock ones in so I can still use the piping from the thermals. There is no way I'm putting the stock piping back on, way too restrictive.
    Either way, there is always bit of trade off when trying to up the ante on performance and power...
  3. Never thought
    Never thought United States 1000 Posts Club!
    1,040
    392
    88
    Arizona
    There was no drone pre-install of the DPs, right?
    • Like Like x 1
  4. Andimal
    78
    15
    Crossville, TN
    If you're asking me, I put them both on at the same time so can't answer that.
  5. Never thought
    1,040
    392
    88
    Arizona
    You may want to try adding a resonator. I’ve read great things about the Vibrant Ultra Quiet Resonator. You may want to try that.
  6. Andimal
    78
    15
    Crossville, TN
    For my knowledge, how do you attach a resonator? Do you have to cut the pipes and weld it in, or attach it some other way? Not too familiar with them and have done limited research.
  7. Never thought
    1,040
    392
    88
    Arizona
    I am no expert but I think they are welded in.
    • Like Like x 1
  8. Hojae84
    Hojae84 United States Active Member
    219
    78
    Bedford, New york
    I went from stock, to ssr downpipes w stock exhaust, now ssr dp and junbl gt catback.
    Holy smokes the combo is loud as hell. I am going to sound deaden the spare tire area soon. Did you just use dynamat or equivalent? Or did you do the whole shebang with the insulating layer after dynamat etc?
    I do think for those who value quiet, downpipes with stock exhaust while not awesome sounding, is an improvement over stock with a lower bassy growl.
    • Like Like x 1
  9. Jwolf
    Jwolf United States Active Member
    101
    26
    Antelope, CA
    I have the SSRs and Ark Grip catback. It is loud and the resonance in that range was pretty bad. I put dynamat in the spare tire area and under the back seats. It made a huuuge difference. There is still drone, and it is still loud, but on the highway at 80 it made it to where the road noise and wind noise is about equally as audible as the exhaust which is fine for me.
    • Like Like x 2
  10. Hojae84
    219
    78
    Bedford, New york
    I guess I'll be dynamatting the tire area at least. Maybe more.
    That dynamat adhesive is nasty gooey stuff.
    I remember replacing my floor carpet on my old shitbox tacoma truck. that went fine, then I decided to dynamat. Little did I know that a dynamat adhesive chunk made it's way onto the sole of my shoe. Then I realised I had lots of black spots all over my new floor carpet.
    Hopefully dont make that mistake here
  11. Hojae84
    219
    78
    Bedford, New york
    Was it pretty straightforward to remove the door sill trim to pull up the carpet? Any gotchas or tips ?
  12. Jwolf
    101
    26
    Antelope, CA
    The trunk area is easy. I didn't pull up the carpet anywhere. Just take out the spare tire and do that area. I didn't take the battery out because I didn't wanna deal with any negative consequences from doing that. In the back seat area I didn't pull up any carpet either except a small patch right behind the seats. You'll see it when you remove the carpet over the spare tire. The seats are easy to get out. Unscrew one bolt on the middle pivot point of the back rests, then pull them out one at a time. Lift the middle out and pull it towards the front of the car until the corner will clear the other section, then pull towards the opposite side of the car. The seats have clips at the front on each side, just pull up firmly, and one bolt on the back side underneath the folding pieces. Remove those and they come out easy.
    • Informative Informative x 2
  13. Hojae84
    219
    78
    Bedford, New york
    Cool thanks for the info :thumbup:
    • Like Like x 1
  14. Socalstinga
    351
    84
    Dynamat... although I have seen lighter weight material that people have said has worked well also. I think one guy used flashing tape from Home Depot (on fb)
  15. Adamdan
    Adamdan Canada Active Member
    381
    64
    I thought about getting the thermal or ark to go with my jun dp. After hearing how loud these setups are I’m happy I have the jun evc coming tomorrow. Downpipes are stop catback is a good way to go for most people. It sounds a little louder and deeper but still super quite on hwy. I wanted louder though. It sounds louder down low but higher rpm in the cabin engine sound over takes it.
    From the outside it sounds good though powerful but not loud.
  16. Andimal
    78
    15
    Crossville, TN
    I put sound dampening all in the trunk, helps some with the resonance, I have to agree with SocalStinga that it is indeed resonance. In sport more where the RPMs sit a little higher you don't really get that low rumble, but definitely when giving moderate gas in ECO mode. I'm going to get under the car and double check everything the shop did tomorrow, and put on the proper clamps that Thermal sent, and arrived today.
    I am getting a pretty strong vibration/buzz in the early gears while accelerating in eco mode. Usually in the 15-35 range with low/moderate gas input. It seems to be coming from the hood area right in front of the drivers seat. Can't tell if it's just hitting that special resonate note, or if something is lose. Went in and tightened up everything I could post intake install, and it's still buzzing occasionally.
    Let me say though, finally opened her up today and she PURRRRRs! Sounds amazing once you get above about 3,500 RMP! Still seems to be a little bit of lag in the gas pedal before it really kicks in, but I'm presuming that's going to remain until I get a tune.
  17. Adamdan
    381
    64
    You might be hearing rasp from the downpipes. I can get some rasp too in the lower gears when I hit the throttle somewhat hard in the lower rpm range it starts around 2000rpm and stops around 2400. Is that when you hear the sound? It almost sounds like a loose heatsheild or something but it’s just coming from the pioes because there is no cat. Also I don’t think the thermal has a resonator so that will make things worst. Do you have a video of the sound?
    • Agree Agree x 1
  18. Kamauxx
    3,126
    1,237
    Thermal has 2 resonators.
  19. Andimal
    78
    15
    Crossville, TN
    No video.. Lose heat shield kind of makes sense, I took it off the other day to put on new hood "vents", and broke a few clips, so I'll replace those and see how it goes. No problems when I hit the throttle hard, it's mostly with slight-moderate input, slowly creeping up between the 1500-2200 range.
  20. Adamdan
    381
    64
    Sounds similar to what my car does. Here is a video of my car this is with door open so it’s sounds really loud in video. Yours sound like this?
Draft saved Draft deleted
Share This Page
