Kinvara8017
@Terry@BMS is it possible to get more out of map 3? I've heard people say they hit 20+ psi yet I'm averaging 17-18psi max? Anything you can do to turn it up a bit?
Boost is only 1/3 of the power equation. If logs indicate timing is maxed out and fueling is sufficient then next stop map5.
