Square Setup for GT
Discussion in 'Suspension, Brakes, Wheels, Tires Discussion' started by TO Turbo, Mar 13, 2018.
  1. TO Turbo
    TO Turbo Canada Member
    25
    24
    Suspension & Tire Gurus: What are your thoughts on running a square (equal width) setup on the GT? According to a vendor on another forum, the car below is running 245/35/20 tires on 20x9 wheels. No offset information is provided but its likely in the 40ish area.
    Not being a huge fan of the stock 19" wheels a thought was to relegate them to winter duty with stock size winter tires, purchase a set of 19" summer wheels and run 255/35/19 all around. I'd reuse the stock rear tires and purchase 2 new PS4's for the front.
    Good idea? Stupid Idea? Mess up the handling? Haven't seen it discussed before so I'm just throwing it out there, partly out of curiosity and partly due to an earlier request fro fresh threads on the forum.
    [​IMG]
    • Like Like x 1
  2. DaJackson
    DaJackson United States Stinger Enthusiast Staff Member Moderator
    642
    285
    68
    Louisiana
    If you are going wider in the front you’ll gain a bit better traction up front, so less pushing through a corner.
    There is no harm in going to a square set up. Generally there isn’t the same amount of room up front to run as of wide wheels/tires as the rear. But if the specs are true in that pic then there is on the Stinger.
  3. mev202
    mev202 United Kingdom Active Member
    169
    82
    London
    Wont square wheels make the ride really bumpy?
    • Funny Funny x 3
    • Like Like x 1
  4. TO Turbo
    25
    24
    Lol. Could be kind of a pre-Flinstones sort of ride.
    • Like Like x 1
  5. westcoastGT
    westcoastGT 2500 Posts Club!
    2,629
    1,200
    Vancouver , BC
    The 19s run pretty firm , 20's for me would like riding on a roller skate , staggered set up looks better and is designed for better handling but it depends on your driving style , my$.02
    • Agree Agree x 1
  6. westcoastGT
    2,629
    1,200
    Vancouver , BC
    • Funny Funny x 1
  7. AAQUINO11
    AAQUINO11 Canada Member
    21
    14
    I just ordered a set of 20x9 +38mm offset for all 4 corners of my Stinger. I don't see any harm in it.
  8. Canoli
    Canoli United States Active Member
    102
    42
    Rockford Illinois
    Getting staggered 19's put on now.
  9. Rocket
    Rocket United States Member
    39
    17
    Michigan
    Actually, staggered setup is designed for traction, not handling. Styling is a big part of the equation, too.
  10. Waynerm002
    Waynerm002 United States Stinger Enthusiast
    816
    352
    68
    DC Metro Area
    I've actually wondered this after seeing the car in person, the front tires have a slight stretch to them on the wheel. Seems like there is room there to go 235, or probably up to the 255 of the rears. I think they can take the car even further but they held back a bit to give the G70 an advantage while still making it an exciting drive or the KIA side. Would love to hear from those that go with a square setup if the handling changes any.
  11. Aquadog
    Aquadog United States Active Member
    233
    116
    If the 20s are fitting on the front and the rear, can you just put the same size 19 that are on the rear, on the front?
Draft saved Draft deleted
Share This Page
