Spark plug boots stuck
Dan Z
Hey guys! Tried changing my spark plugs today. When pulling out the coil packs they popped off the boots, and for the life of me I could not pull the boots out of the cylinders. I had two needle nose pliers pulling and twisting, I got one of them out but could not get any other (actually tore one). Wondering if you have any tips for removing the coil pack boots?
Try spraying some WD-40 around and inside them, work it with a small screwdriver.
Are they stuck on the plug or the inside of the tube?
If they are stuck be very careful removing the plugs, you might wanna let the wd-40 soak around them as well.
Broken plug threads are not fun!
It appears the boot is stuck on the plug, because I'm able to stretch and wiggle the boot.
