NICK_KHAR
Authorized Vendor
NEW PRODUCT!
Finally released and in stock!
Riaction full coilover suspension kit!
Great for street and track use!
8k front spring and 10k rear
Fully rebuildable
Camber plates included!
There’s only 10 sets in stock and they will go quick!
Riaction Monotube Coilover Kit - Kia Stinger All Models 2017-2020
Tired of dealing with Lowering Springs and not getting the desired drop?
Do you want to fully dial in your suspension system?
Are you a weekend warrior looking to take advantage of the G70/Stinger chassis?
Based on the Mono-Tube system with ride height and damping adjustments, Riaction sport coilovers can be customized to match your driving style.
Riaction uses quality materials merged with precision design to deliver a unique, and fully rebuild-able coilover.
Coilover Kit Features
Also fits all models of the Genesis G70 2.0/3.3 AWD RWD
NOTE : Stingers/G70 with Electronic Suspension will need Error Cancelers otherwise there will be a "Check Suspension" light at startup
Fully rebuildable
- Full Length Ride Height Adjustment
- Spring Rates : 8kg Front / 10kg Rear
- 32 Damping Adjustment Levels
- Mono-Tube Damper Design
- Seamless 52mm Electroplated Carbon Steel Shock Body
- Unique 44mm High-Flow CNC 6061 Aluminum Piston
- Unique Thinned CNC 6061 Aluminum Floating Piston
- Polyurethane Oil Seal
- SAE9254 Cold-Wound Spring
- Multi-Thickness Valving Shims
- Unique Low-Gas Pressure Design
- 7.5w Compounded Suspension Fluid
- Fully Rebuildable
