Rear sway bar installation (shop or diy)
You can install sway bars with just four simple methods. Step 1: secure the tow vehicle and trailer in place. Step 2: Positioning the ball’s post. In this step, you have to pass the shaft of the sway control ball through an empty combination and then tighten the nut and lock washer that approached the ball using a socket set to secure it in position on the ball. Step 3: Drill holes through the tongue rail. You need to drill four holes through the tongue rail at the indicated locations. The last step is to apply lubricating oil to both sway control balls.
What is the point of this? I get that it's a bot, but whhhhy?
Also, old post now, but thanks for the advice everyone (except for this silly bot post). I'm about to do my own sway bars and the info was helpful.
