Reading codes
Omega
How do I go about using the jb4 to read my car’s codes?
Simple, if you have it hooked up, and the OBDII cable is connected properly (you can tell when the engine is running if the display of most parameters other than boost seem correct), and you have a jb4 app (phone usually), just press the "codes" button (with the big exclamation point) and then "read codes"
