QUESTION FOR ECU
Jxcruz
Bay Area, San Jose
Hello,
Ive been wanting to adjust the settings on my ECU and was wondering if I should get a LOZIC tune or if I should just purchase the EK1? I live in CA so obviously 91 is the highest octane we have. I just want some burbles and the options that LOZIC has on his ECU tune are some of the options I want to mess around with. Which route is better, LOZIC or EK1?
Performance wise you don't even need ECU tune at all if you're knock limited on CA91. You would be lucky to be able to run JB4 map1 on that horsepee fuel.
If you go with lozic just go order something like 1.2 bar tune. 1.3 bar will need religiously E30mix already. For EK1 route you can't handle race BEF at all. You have to go ask Terry by email for that "pump" BEF with basically stock timing and pray your fuel is good enough for map1.
Also be mindful that burble tune will foul your stock cats faster than you think.
